Author Topic: Unsiezing an engine?  (Read 978 times)
Offline DarkRider
« on: September 19, 2008, 03:44:30 AM »
Ok as i have mentioned in another thread i have gotten a rebuilt CB550F engine from my roommate. However it sat for a brief time without the header and carbs on it so it is currently siezed. On the upside is that it has only been like this for 2 months at the max because it was left outside when we had some bad rainstorms. What is the easiest way to free the engine in this case?
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
KingCustomCycles.com
Re: Unsiezing an engine?
« Reply #1 on: September 19, 2008, 04:00:34 AM »
I have had good luck:
remove sparlplugs
remove left and right crankshaft covers (stator, points)
Fill each cylinder full of ATF, Marvel Mystery oil, any thin penetrating oil, with tube & funnel
let sit 1-3 days
try to crank with starter direct to battery
try to turn with kick starter (usually inneffective)
try to rock with stator or points bolt (be very gentle)
try both electic starter and stator bolt at same time for short periods to not stall and overheat starter
If it is still stuck, warm the cylinders in the ring area of each with a propane torch
If it is still stuck. tap the top of the highest piston lightly with a wood dowel & hammer
Any and all combinastions of the above have freed my engines.  One had sat for 5 years with no sparkplugs outside.  I had to remove the leaves from ontop the engine to put the oil in.
Good luck (prayer helps)
Offline Hush
« Reply #2 on: September 19, 2008, 05:25:38 AM »
I'd go along with the soak and leave myself.
Should still be a runner if only 2 months out of service.
Offline DarkRider
« Reply #3 on: September 19, 2008, 05:29:31 AM »
Thanks for the info guys. I will try the soaking first and progress down the list if it doesnt work.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline Leemata
« Reply #4 on: September 19, 2008, 09:18:00 AM »
I agree with the King up there, but you might consider substituting PB Blaster.  You can find it at Ace Hardware, Autozone, etc.  Worked well for me on an engine that had been sitting since '97.  Just don't be in a big hurry.  Also, you can probably expect it'll need a bore job after it's loose.
Terry
'78 CB750F, '72 Honda Z50, '74 Honda Z50, '78 Maico MC250, '98 Yamaha YZ250, '75 RD350B
"Ah yes, Harley Davidson.  You really have to give them credit.  They've managed to create a market in which they can sell yesterday's technology at tomorrow's prices." (Michael Kasmirsky)
Offline speedy gonzalais
« Reply #5 on: September 19, 2008, 02:11:01 PM »
ive seen people use very mild acids in the past works in minutes thats if the rings are rusted to the bores, It would prob be wise to ease the barrels off and check the rings and clean out any rust that migt scratch the pistons and bores.
82' C90
87' yamaha T80
79' CB125T/CD200 project
82' CB650z
80s kawasaki ae50/150cc project
92' Suzuki GSXR600
80' CB250N
