Author Topic: remove the gas tank  (Read 1522 times)
Offline andy8190
remove the gas tank
« on: September 21, 2008, 02:36:19 PM »
can someone tell me how to get the tank off, i know to disconnect it from the petcock, it it screwed down or anything?
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
Re: remove the gas tank
« Reply #1 on: September 21, 2008, 02:42:58 PM »
Don't know what you have, but most (all?) have a rubber retainer at the end, just infront of the seat.  Lift the seat up, pull this off the rear tab of the tank and then slide the entire tank off towards the rear of the bike.  Don't forget to unhook any hoses.
spwg
Offline andy8190
« Reply #2 on: September 21, 2008, 02:48:08 PM »
ok thanks, i have 550 four.
Offline andy8190
« Reply #3 on: September 21, 2008, 08:36:27 PM »
thanks i got it off earlier today without a problem. so what is the difference between 550k and 550f i have a 550 four is that the f?
Offline andy8190
« Reply #4 on: September 21, 2008, 08:48:03 PM »
how can i determine what 550 four i have?
Offline andy8190
« Reply #5 on: September 21, 2008, 09:23:45 PM »
it says cb5501018560
Offline andy8190
« Reply #6 on: September 22, 2008, 08:26:45 PM »
so i went to clean my petcock and i didnt find a sock on it? where would it be or could it just not have had one on it?
Offline andy8190
« Reply #7 on: September 22, 2008, 08:41:10 PM »
sure thing, thanks and look at my other post bc the bowl is butcher on the petcock i will post the pic here too
Offline andy8190
« Reply #8 on: September 22, 2008, 08:41:58 PM »
does the looks of this call for a new one?
Offline andy8190
« Reply #9 on: September 22, 2008, 08:47:38 PM »
thats not rust on the screen its something else bc i scratch it and it runs white. i tried carb cleaner on it and it didnt budge
Offline andy8190
« Reply #10 on: September 22, 2008, 09:00:41 PM »
the white stuff on the oval ring is actually like a rubber substance, so do i need to get all that stuff in the bottom of the bowl out? does it matter that it is all scratched up like that?
Offline andy8190
« Reply #11 on: September 22, 2008, 09:14:20 PM »
ok thank you for all the help. i will try and scrap that stuff out of the bottom of the bowl, the sides of the bowl have be butchers so actual metal debris was in there. if i get all the metal debris out and that staff in the bottom out will it still be good?
Offline andy8190
« Reply #12 on: September 22, 2008, 09:17:07 PM »
ok sounds good. the petcock was in horrible shape so maybe that will help my problem a lot.
where can i buy mineral spirits
Offline andy8190
« Reply #13 on: September 22, 2008, 09:27:19 PM »
ok sounds good. that is gonna be the project for tomorrow. any auto parts store will have the spark plugs i need huh?
