Author Topic: Motion Pro SyncPro  (Read 6988 times)
Offline ev0lve
Motion Pro SyncPro
« on: September 22, 2008, 01:19:06 PM »
Can anyone tell me about carb sync tools? I bought the Motion Pro Sync Pro and I'm wondering if I made a mistake and should have gotten real vacuum gauges.
Basically I assembled it per the instructions; restrictors in the tubes, turn out the adjusters, hook up the manifold, plug it into the vacuum port of 1 to attempt calibration, start bike. Immediately the first 2 tubes fluid suck up into the hose and the other 2 are way high. Looks like the fluid is a goner for those two.
Did I do it wrong? The restrictors are in and level in the hose. I even cut them out and placed them again? WTH? Did I throw a $100 away on this tool? Anyone have experience with this gauge?
The guys at MotionPro suggest using a hemostat when hooking it all up and if they're cheap enough I will or I'll just rig something up (fingers? ) and also are sending out some replacement fluid but I'd like to not repeat the mistake if I don't have to.
Aftermath attached and thanks for any advice.
« Last Edit: September 22, 2008, 01:21:48 PM by Iggy »
Offline twallace
Re: Motion Pro SyncPro
« Reply #1 on: June 06, 2011, 06:52:02 PM »
I know this is old but I wish I had read it before throwing away $100 on this useless gauge. No matter what I do the fluid gets sucked out of mine. Either my bike has magical suction powers or this thing is crap!
Offline WarwickE36
« Reply #2 on: June 06, 2011, 07:03:02 PM »
I have a 100 dollar EBAY vacuum gauge kit and it is awesome.  It dramatically reduced engine noise associated with the carbs being out of sync, as well as smoothing out my lumpy idle.  It is easy to hook up and comes in a nice blow molded case.  Since these bikes require constant attention (especially if you bought a non running bike like I did) it is definitely worth the 100 dollar investment.  I will surely use this tool more than once making it worth more than what I paid for it.  I have spent FAR more for tools off the MAC and Snap On truck, and this tool is equal in quality.  I got mine from Sin City Cycle Parts and the shipping was incredibly fast and fairly prices.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline splitt
« Reply #3 on: June 06, 2011, 08:21:46 PM »
You can contact Motion Pro about refills for the liquid. They sell refill kits.
Make sure that you have your idle at the correct speed. High RPM's cause excessive vacuum. Don't crack the throttle either. You need to install those restrictors in the hoses also.
Offline Really?
Motion Pro SyncPro
« Reply #4 on: June 06, 2011, 08:35:00 PM »
That tool is garbage. $100 wasted on my part. I got the free fix kit from them because it was broke when I got it. It was better after the fix kit but still junk. Love the vacuum gauges I got.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline twallace
« Reply #5 on: June 08, 2011, 07:11:24 PM »
For anyone in Canada looking for gauges...Princess Auto has nice vacuum gauges on sale for $14 each. They come with restrictors and tubing and all four of mine read exactly the same when I hooked them up together. Will sync my carbs tomorrow with them and report back.
Offline Johnie
« Reply #6 on: June 08, 2011, 07:17:19 PM »
Morgan Carbtune all the way. Never a problem and carbs are right on the money. All the bikes run great after a nice sync. Check it out...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Frankenkit
  • Industrial Strength
« Reply #7 on: June 08, 2011, 08:02:51 PM »
+1.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: June 08, 2011, 08:16:01 PM »
That just proves it's junk. You're supposed to blip your throttle after making carb adjustments to make sure the idle is settled down.
I got the 4 gauge vac sync tool. It works good enough.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline splitt
« Reply #10 on: June 08, 2011, 09:15:48 PM »
"That just proves it's junk. You're supposed to blip your throttle after making carb adjustments to make sure the idle is settled down."
You're correct, you are supposed to blip the throttle to make sure that all of the slides return to their normal position to get a true reading. The problem that I've noticed is that some people don't know the difference between blip & WOT. I've used Motion Pro mercury sticks both at home, and when I was a mechanic at the Motorcycle shop that I co-owned. They are the most accurate gauges that I have ever owned. Maybe the kind that you are using are a different style from mine. The set I have is about 17 years old.
I also have a set of early 70's Honda mechanical gauges that are absolutely worthless. The mechanical gauges bounce around so bad that there is no way to get any sort of accurate reading from them at all. Since they are still in the original box, they make a good conversation piece though.
Offline Really?
« Reply #11 on: June 08, 2011, 09:24:06 PM »
The Motion Pro I have has blue fluid not mercury.  It was sucking it up without blipping the throttle.  It was setup per their instructions.
« Reply #12 on: June 08, 2011, 09:40:14 PM »
if you use guages you must have a damper valve to control the pulses,like these have.
click on the dime city ones and enlage the picture,those also read pressure,i hope they can be calibrated because at rest two are showing different?in fact three if you look close at the most left one just out of view,look at the tail end of the index pointer.
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-tools-4-cyl-carburetor-vacuum-gauge-sync-kit-84-68594.html
« Last Edit: June 08, 2011, 09:46:37 PM by dave500 »
Offline c(b)hris
« Reply #13 on: June 09, 2011, 07:16:05 AM »
mine are different at rest too but read pretty much the same when each is hooked up to the same cylinder.
75 CB550
74 CB750
Offline Really?
« Reply #14 on: June 09, 2011, 08:27:30 AM »
Hey Iggy, that is what mine did out of the box and after the fix kit.  I would say your $100 is a waste just like mine was.
Offline Johnie
« Reply #15 on: June 09, 2011, 11:53:51 AM »
I think we should do a FAQ on the Motion Pro system to keep guys from wasting their money on them. I have seen this problem numerous times and hate to see you guys spending money on those problematic systems. There are a number of units out there that will work and the Morgan keeps coming up as one of the best. No affilation to the company, just a dang reliable unit.
About $98 shipped to USA.
http://carbtune.com/
« Last Edit: June 09, 2011, 11:55:38 AM by Johnie »
Oshkosh, WI  USA
Offline Frankenkit
« Reply #16 on: June 09, 2011, 02:19:19 PM »
But also maybe list people who have them who are willing to loan them out to those who need them... If anyone in the PDX area needs to borrow mine, I can def. arrange that.
1973 CL350- Lola?
Stuff for sale
« Reply #17 on: June 09, 2011, 03:09:03 PM »
the motion pro tool must be synced EVERYTIME you use it ..(if you turn the bike off you have to sync the tool again)
you hook all 4 hoses up to a splitter, so all 4 hoses are run to the same carb (it comes with it) and sync the tool on the one carb ,   then it's ready to be hooked up to all 4 carbs
it's a serious pain in the ass , had i known this before hand i wouldn't have gotten it either ...BUT .. after you do all that nonsense it works great   for me anyway ... i can rev the bike all i want
the mercury motion pro i used to have worked great ... i miss it
Offline gnarlycharlie4u
  • Far from being an
« Reply #18 on: June 09, 2011, 04:03:48 PM »
did you hold the tool vertical (upright) or lay it down at all? that might make a bit of difference.
Offline twallace
« Reply #19 on: June 09, 2011, 07:47:05 PM »
Hooked up my $14 vacuum gauges tonight and they worked perfect. These come with built in restrictors so there bounce in the needles.
No 2 cylinder was 1/3 what the others were so its no surprise my bike idles and runs much better now.
Anyone want to buy a SyncPro for half price?
Offline CycleRanger
  • No comment about being an
« Reply #20 on: June 09, 2011, 08:18:42 PM »
Now that's the grin of a man with a smooth running Honda! ;)
Offline grcamna2
« Reply #21 on: June 09, 2011, 09:00:17 PM »
    I love my gauges;they are German made & marketed by the PCCC Co.
I purchased them when I first went into my M/C repair business.
I have found the best way to get a lasting Synch is to adjust the carbs.
complete i.e. matching All float levels,cleaning All individual pods,clearing All
carb. vents,etc.  Timing - spot on, Valve adj., etc. , etc.  It's alot of labor,but
when you take your time and apply plenty of TLC to ea. area...THEN when you
synch your carbs..well, the synch will hold for many more miles. I think that
the synch will stay on the carbs that way, while the valve adj.,timing,etc. will
be the things that need to be adjusted in a preventative manner.
  You really can gain good ground in  all around performance from your stock
set ups w/o any mods by just keeping ahead of the battle w/ fine tuning.
                  ENJOY  THE  SMOOTH  RIDE...AND  HAPPY  TRAILS !
  • Far from being an
« Reply #22 on: June 09, 2011, 10:24:49 PM »
LISTEN TO THIS MAN! you're definitely right,  a sync is the last thing you want to do.
