Author Topic: gas cap thumb latch broke. Now what??????  (Read 6270 times)
Offline friedfish80
« on: September 24, 2008, 02:15:23 PM »
After paying a lot of money for a thumb latch for my resto project it broke on me. Snapped right in half. I know and understand that this part is unavilable everywhere. And the local junk yard told me "good luck finding that one". Im shure im not the only one thats had this problum. What have you all done? What sugestions are out there to get a cap on a OEM tank. And BTW its a tank from a 74 750 K model.
Offline WFO
  • Will work for powerbands
Re: gas cap thumb latch broke. Now what??????
« Reply #1 on: September 24, 2008, 03:28:41 PM »
I seem to remember another thread about the same problem if i remember correctly that part is dicontinued but you can replace it with a locking catch kit ( check ebay)
82 cb650 sc nighthawk - 78 kz 650 b
Offline kghost
« Reply #2 on: September 24, 2008, 03:37:11 PM »
Stranger in a strange land
Offline Raul CB750K1
« Reply #3 on: September 24, 2008, 03:37:24 PM »
The search button is your friend.....
Offline WFO
Offline friedfish80
« Reply #5 on: September 24, 2008, 04:31:27 PM »
Ummmmmm check that allready buddy.
Offline olds-cool
  • Choppa Guy
  • Choppa
« Reply #6 on: September 24, 2008, 07:42:17 PM »
My latch broke too.  I happened to get another tank with a good latch.  A little drilling with a small bit removed the pin and gave me a good latch.  Now the hard part, finding a suitable replacement pin.  I looked in the bolt section of Lowes and found a sort of pin.  I don't know the exact name of it at the moment.  It is a hollow cylinder with a lengthways slit which allows it to be somewhat compressed.  I found one that was the same diameter of the stock pin and just a hair longer.  I haven't had time to run out to the garage and try it yet since I just moved into a new house and am busy as heck unpacking.  If I remember, I'll post back to let you know how it goes.
Offline Johnie
« Reply #7 on: September 24, 2008, 08:55:31 PM »
Geez, don't drill those pins out guys.  They are a hard item to find.  When I had my cap rechromed on my KO this winter I used a very thin punch.  I carefully punched the old pin out which just wrapped the bent hollow end up.  When I got the items back I put the pin back in and used a BB on the end of a C-clamp to crimp the end back again.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #8 on: September 24, 2008, 10:29:53 PM »
Cap pins are still available, Latch pins aint---only the replacement lock assembly which is a 400 four part
Offline goon 1492
  • Sucka Repellant
« Reply #9 on: September 25, 2008, 06:58:35 AM »
I thought hondaman had some pins he was sellin', or am I wrong?
Offline Johnie
« Reply #10 on: September 25, 2008, 01:42:02 PM »
Bryan...cap pins are still available from Honda?
Thanks
Oshkosh, WI  USA
Offline wildcatmahone
  • Poseur
« Reply #11 on: September 25, 2008, 06:04:28 PM »
That's what's called a "spring pin".
Not stock looking at all but what I used was I bought some stainless M3 socket cap screws from bolt depot. Measured the cap and spring latch pin and ordered them a little oversize. Cut them down to what they needed to be and topped the off with some stainless acorn nuts...Looks great!
« Reply #12 on: September 25, 2008, 07:16:23 PM »
I make replacement stainless steel (non-sparking type) screw kits with satin-finished parts, look nice. $4.40 for one set, $6.80 for two in the same shipment (add $2.40 for each additional set in the shipment). Most of the proceeds return to SOHC4.net . Drop me a PM if you guys need some.
Yep, still do...
Offline friedfish80
« Reply #13 on: September 25, 2008, 09:58:42 PM »
Ok good we got the pin covered.
But what about the latch that broke?
« Reply #14 on: September 25, 2008, 10:11:01 PM »
I repeat---you now have to buy the lock assembly as fitted to 400 four 17550-377-315
Offline kghost
« Reply #15 on: September 26, 2008, 08:41:06 AM »
I don't think he wants the lock....personally I hate the lock.
Its big bulky and ugly. I like the Latch
Offline phactory
  • Motorcycle Rescue
« Reply #16 on: September 26, 2008, 10:33:39 AM »
The replacement lock was a safety recall for ALL Honda's with the clip type latch, not just the 400 Fours.
It is always a good idea to depress the latch when closing the cap, instead of snapping it closed.
Phil
« Last Edit: September 27, 2008, 10:51:32 AM by phactory »
Offline ieism
« Reply #17 on: September 26, 2008, 10:54:17 AM »
I advice you to look around for a few weeks. That tread you saw before was one I started a few weeks ago.
I need the latch also, and everyone told me it was impossible to find. I found it in a regular honda bikeshop, bought two latches (one for my friend who was looking for one too) and 12 cylinderhead bolds, the bill as around 35 Euro. That were the last ones they had, or I would have bought all of them.
I'm sure someone on a scrapyard or some old shop must have some, just be patient.
---cb550---
Offline friedfish80
« Reply #18 on: September 26, 2008, 11:59:25 AM »
I would settle for a lock. when faced with not haveing anything ill take it! expecialy with gas being $4 a gallon now a days.
Offline Johnie
« Reply #19 on: September 26, 2008, 06:17:54 PM »
Thanks
Bryan...what is the "cap pin" number from Honda?  My book just lists the entire assembly and not the individual pin?
Thanks
Oshkosh, WI  USA
Offline mcpuffett
« Reply #20 on: September 27, 2008, 03:23:43 AM »
Hi Johnie, my parts book shows part number 17513 300 300, and in the parts book its called , (pin, fuel filler cap check), cheers Mick.
Offline Johnie
« Reply #21 on: September 27, 2008, 10:11:42 AM »
Thanks Mick!!!
Oshkosh, WI  USA
« Reply #22 on: September 27, 2008, 10:16:32 AM »
Mick, thats the catch pin number that you cant buy.
The one you want is17514-323-300 if its a K2 upwards "Pin B Fuel Cap"
Offline mcpuffett
« Reply #23 on: September 27, 2008, 12:00:54 PM »
My mistake Bryan  :-[, i thought Johnie was asking for the part number for the thumb latch, cheers Mick.
