Author Topic: Left Hand Switch Cluster  (Read 1595 times)
nashvegas
« on: September 16, 2005, 08:43:32 AM »
I was just wondering about the wiring on the L/H switch for the CB400F.  On my bike I have an insulated wire the runs from what looks like clutch lever to the wiring harness.  What is this wire and what is its purpose?  The parts manual refers to it as the cam SWITCH ASSEMBLY CLUTCH LEVER (Part No. 35360-341-000)
Thanks,
Matthew
Offline Killer Canary
  • Typical Bran Muffin
Re: Left Hand Switch Cluster
« Reply #1 on: September 16, 2005, 08:55:10 AM »
If it's like my 550, it's that's the clutch safety inter-lock switch; it prevents the starter motor from engaging while the bike isin gear and the clutch lever is out(disengaged). Itshould measure 0 ohms across the terminals with the lever pulled in.
Kawi GPz900, H1
nashvegas
« Reply #2 on: September 16, 2005, 09:35:10 AM »
Hey Thanks, is that wire replaceable?
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #3 on: September 16, 2005, 07:28:13 PM »
At the clutch handle end, there is a tiny switch embedded in the hinge that attaches to the handlebar. It seems that the wires tend to bend and break about 1 -2 inches from the handle end. Probably from years of flexing. If you disconnect the wires behind the headlight and disconnect the clutch cable, you can pull the cable out through the handle end. But will have to readjust the clutch after you put it back together. I repaired mine by carefully striping about 2 inches of insulation at the clutch handle end, wrapped the wires with a little tape, disconnected the wires behind the headlight, and slid a 3 inch piece of black heat-shrink tubing over the cut. Shrunk right over, is almost invisable, and is stronger than before. reconnected the wire and it took 15 minutes.
Fonda Honda
