Author Topic: Valve train problems  (Read 1087 times)
Offline rchrdms
  • Honda CL350 Twin '72
    • Richard F Meese
« on: September 25, 2008, 07:07:22 PM »
Hi,
After eliminating all other problems I found that my 72 CL 350 Twin has a low compression problem. It seems to leak air out of the left spark plug hole.
A compression test told me the problem is probably in the top end.
I took it apart and noticed no probs with the head gasket, but I did see very unusual wear on the rocker arm lobes and cam shaft at the problem cylinder. There was also a gunge with
metal shavings covering the cam where it turns in the side cover housing.
What do I do about this one? I don't know what would cause that kind of grinding. The rockers are visibly more worn on the trouble cylinder than the ok one(it has a nice shiny finish there). What do I test? Would a bad valve cause that, or am I looking at replacing the cam. Of course, I want to find out what is warping the camshaft that way.
Thanks,
Richard
Re: Valve train problems
« Reply #1 on: September 25, 2008, 07:38:34 PM »
It is not getting Oil where it should get Oil..
« Reply #2 on: September 26, 2008, 01:25:31 AM »
Centrifugal oil filter blocked, replace cam, cam bearings, rocker arms and gaskets/seals plus thorough internal cleanout
Offline rchrdms
    • Richard F Meese
« Reply #3 on: September 27, 2008, 11:42:46 AM »
Thanks, guys.
I agree with your idea. I'll check the passages at the top end.
My cam doesn't have bearings, just the side covers it turns in.
Any ideas where I can get a cam and a pair of rocker arms?
Richard
« Reply #4 on: September 29, 2008, 08:39:23 AM »
The end covers ARE the bearings and will need replacing with the cam
