Author Topic: Sandcast Cb750  (Read 2234 times)
velo13533
Sandcast Cb750
« on: September 16, 2005, 08:23:03 PM »
How do I  identify a sandcast CB. There is no engine  number stamped in the usual spot.Would the frame number tell me what year it is. It is advertised as a 1969 model, but I need to confirm that.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Sandcast Cb750
« Reply #1 on: September 17, 2005, 02:30:39 AM »
The frame number should be on a riveted plate on the right side (as sitting on the bike) of the neck. It should also be stamped directly into the neck itself on the opposite side of the neck. The sandcasts are the first/earliest and limited to VIN numbers below 1007415.
Offline Gordon
  • 750K1, 550K2
Re: Sandcast Cb750
« Reply #2 on: September 17, 2005, 06:35:30 AM »
Even if it turns out to be a "Sandcast" based on the VIN, the engine cases are no longer the original sandcast ones.  The lack of an engine ID number means the cases have been replaced at some point, most likely due to a broken chain.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Sandcast Cb750
« Reply #3 on: September 17, 2005, 06:39:08 AM »
"There is no engine  number stamped in the usual spot"
Gordon's right. Mine is definately not sandcast anyway (based on VIN) and my engine number is blank also. I suspect it suffered a cracked or holed case from a chain snap somewhere in its past and the new case just wasn't stamped.
Offline MikeDeB
Re: Sandcast Cb750
« Reply #4 on: September 17, 2005, 11:06:29 AM »
A blank engine number pad indicates replaced cases.  Heads and cylinders from a sandcast will have a very rough texture as compared to later die cast components so it's possible to have part of a sandcast motor.  Also, it's not the VIN number that identifies a sandcast, it's the engine number.  It has to be below 7415 for it to be a sandcast.  At engine number 7414 the frame number will be higher than 7414.
Mike (Old SOHC/4 #2641)
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
97 Ducati 900 SS/SP w/FCRs
98 Ducati 750 Monster w/FCRs
80 SR500
"Growing older is inevitable, growing up is an option."
Offline Bob Wessner
  • "Carbs Suck!"
Re: Sandcast Cb750
« Reply #5 on: September 17, 2005, 01:12:59 PM »
"Also, it's not the VIN number that identifies a sandcast"
True, sorry, shouldn't have used the term VIN here.
Offline MikeDeB
Re: Sandcast Cb750
« Reply #6 on: September 18, 2005, 06:18:36 AM »
No problem Bob, I knew what you meant.   :)
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
80 SR500
Offline KB02
Re: Sandcast Cb750
« Reply #7 on: September 18, 2005, 10:30:39 AM »
The VIN plate should give you all the info you need to identify the bike (right on the steering Neck). It should list both the production date and model year of the bike. Mine, for example shows "Production date 07/75" and "Model Year 1976."
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline MikeDeB
Re: Sandcast Cb750
« Reply #8 on: September 18, 2005, 05:39:53 PM »
They must have started doing that late in the production run of 75 K models.  Mine was built 9/74 and has no model year on the VIN tag.  Neither do my K2 or K1.
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
80 SR500
