A blank engine number pad indicates replaced cases. Heads and cylinders from a sandcast will have a very rough texture as compared to later die cast components so it's possible to have part of a sandcast motor. Also, it's not the VIN number that identifies a sandcast, it's the engine number. It has to be below 7415 for it to be a sandcast. At engine number 7414 the frame number will be higher than 7414.
