Author Topic: 400 pipe on a 350  (Read 3236 times)
Offline fergie
400 pipe on a 350
« on: April 13, 2005, 10:06:22 PM »
will a 400 pipe fit a 350,also does anyone make pipes for a 350 anymore.thinking about buying a 74 350 and I just want to know what I'm getting myself into.
The most interesting man in the world
El Taco
Re: 400 pipe on a 350
« Reply #1 on: April 13, 2005, 10:08:12 PM »
If it's a twin, I have the exhaust for you. Got the head pipes in nice shape, and a pair of harley mufflers that will slip on nicely.
Offline fergie
« Reply #2 on: April 13, 2005, 10:11:21 PM »
its a four . fergie
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: April 14, 2005, 03:36:12 AM »
If I remember correctly, the only issue with putting the 400 pipes on a 350 is the mounting point for the muffler.  I you can fab something up yourself, then it's do-able.
Offline kghost
« Reply #4 on: April 14, 2005, 07:07:11 AM »
I just put a set of MAC  mufflers on my CB350F. They went on relatively easy. I did have to shorten the stock headpipes just a little. In my case that was a good thing since one pipe had a hole right where it joined the muffler.
Stranger in a strange land
Offline Bryan Boyle
  • SOHC4 #47 ...one of the Old Pharts
    • The Other Hobby: Restoring Lotuses
« Reply #5 on: April 14, 2005, 09:34:30 AM »
I know about the MIVV mufflers for the 350f, but, who's making pattern parts?
Bryan
SOHC4 #47
Proud member since 1994, active on and off
Commercial Pilot/Flight Instructor-Instrument/A&P
Morrisville PA
'63 CA95, '64 CA77, '73 CB350F, '73 CB350F, 2 Lotus Europas and Lots of Parts All Over The Place
El Taco
« Reply #6 on: April 14, 2005, 12:15:03 PM »
its a four . fergie
Argh....Can't remember. I have a couple 350Fs, but do I have exhaust?????
If I do, it'll go cheap. Nobody should pay that much for a set of pipes. Are you talking about the head pipes, mufflers, or the whole set?
motodude
« Reply #7 on: April 18, 2005, 08:59:32 AM »
I've got a spare set of NOS, in-the-box exhausts (4 into 4) for the CB350F that I'll be putting on ebay soon.  The #2 pipe (lower left) - the rarest item on these bikes - is used but in excellent condition.  I'm gonna include a complete set of NOS head mount flanges (the finned ones), and both sides rear mounting brackets, so you can basically bolt them on as soon as you get them.  A set like this recently went off on Ebay for nearly $1600.  I'll take $1200.  Email me if you're interested.
don_m
« Reply #8 on: April 20, 2005, 09:13:50 AM »
Gordon is correct.  I'm using the 400F header into a Supertrapp muffler as the original system was too restrictive for my uprated engine.  Also found original air filter restrictive so cut out filter material & fitted Uni-Filter foam from bulk stock.  This requires increasing the main jet one size up.
Don
