Author Topic: Oil Pressure switch prob?  (Read 2107 times)
Offline azuredesign
  • Knupping pin
« on: October 01, 2008, 03:38:31 PM »
No current to indicator light. Is the best way to test the switch to test  impedence? Is the switch open or closed when there is no pressure? I'll test the harness as well, but had no problems before removing and replacing engine.
Thanks for any help!
Ben
Offline mystic_1
  • 1970 CB750K
Re: Oil Pressure switch prob?
« Reply #1 on: October 01, 2008, 03:53:01 PM »
Switch is closed when there's no pressure, completing the circuit to ground.  Test by disconnecting the lead at the switch and touching it to a ground point, light should come on.  If not, your problem lies elsewhere.
mystic_1
- John Augustus Shedd
Offline azuredesign
  • Knupping pin
« Reply #2 on: October 01, 2008, 04:13:14 PM »
Thanks!
Offline Drewery
« Reply #3 on: October 01, 2008, 04:25:58 PM »
I 'fixed' mine a couple of times when i first had the bike - then I gave up. Now its either on all the time or never on. I found it's way easier to check the oil level once a month.
72' CB500K1
69' Triumph GT6 plus
troppo
« Reply #4 on: October 02, 2008, 02:04:50 AM »
Until it goes BANG
Offline Drewery
« Reply #5 on: October 02, 2008, 04:31:38 AM »
The last time I changed the switch was in '79'. If it goes 'bang' soon I'll have done okay and I guess I'm ready for that rebuild. Probably fix first gear while I'm at it.
72' CB500K1
Offline azuredesign
  • Knupping pin
« Reply #6 on: October 08, 2008, 12:39:31 PM »
Yep light comes on when switch is bypassed. Time for a new switch.
Thanks!
mystic_1
