Author Topic: What's this doohicky on the frame?  (Read 1267 times)
Offline bunghole
« on: October 04, 2008, 05:27:53 pm »
I'm grinding all superfluous nonsense off of my '77 750K frame.  What is this little rectangular tab on the right of this picture?
It is centered between the left passenger peg mount triangle (which I've removed).
Thanks!
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
KingCustomCycles.com
Re: What's this doohicky on the frame?
« Reply #1 on: October 04, 2008, 05:53:08 pm »
I believe that is a retaining tab for the cosmetic plastic cover above the chain guard.
Offline bunghole
« Reply #2 on: October 04, 2008, 06:41:07 pm »
Que?
I don't remember no cosmetic plastic cover.
Watchoo talkin' 'bout Kingis?
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline bunghole
« Reply #3 on: October 04, 2008, 06:43:25 pm »
Nevermind.  I just found the piece you were talking about.  There should be no issue in removing that piece and therefore the tab, correct?
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
martino1972
« Reply #4 on: October 04, 2008, 07:00:08 pm »
if you leave enough tabs to some what hang the engine in and at least one point to bolt a wheel too and maybe a tank,you can grind away as much as you want... :D :D :D :D :D
Offline bunghole
« Reply #5 on: October 04, 2008, 07:12:56 pm »
I'm down to what looks like a broomstick with a loop-like thing on the end.  Is that enough?
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline Hush
« Reply #6 on: October 04, 2008, 07:42:27 pm »
Marti will pop around with his truck mounted uber welder to glue all the steel fillings back together when you get finished, should be enough left over for a 350 frame and maybe a key ring. ;D
