Author Topic: Opinions about these pistons?  (Read 1941 times)
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« on: October 05, 2008, 12:05:04 PM »
My '76 750F has a head gasket oil leak that's getting severe enough that oil is blowing back on my pants.  Not a gusher, but a pretty good weep.  I figure that if I'm going to take the time to pull the thing out to replace a gasket, I might as well freshen things up.  Not interested in going the 836 hotrod route.
Anyway, I've been looking around for parts and what I need/want to do.  I may wind up needing to go with oversize pistons and found these repros.  Anyone have an opinion or experience with these?
http://www.cmsnl.com/products/piston-025-repro_06132371000p/
spwg
Offline speedy gonzalais
Re: Opinions about these pistons?
« Reply #1 on: October 05, 2008, 02:15:18 PM »
are you reboring the cylinders?
82' C90
87' yamaha T80
79' CB125T/CD200 project
82' CB650z
80s kawasaki ae50/150cc project
92' Suzuki GSXR600
80' CB250N
  • I'm not really a
  • 1976 750 F
« Reply #2 on: October 05, 2008, 04:17:10 PM »
Don't know yet, probably.
I'm pretty green at this so I've got some more research to do.  Just trying to find out what's out there and have a good idea about what I'm gonna need before cracking the thing open.  Figure I'll buy the stuff I know I'll need before I start, then get the rest when I find out the condition inside.
spwg
Offline Clyde
« Reply #3 on: October 05, 2008, 04:36:54 PM »
The pistons look good and are a reasonable price.
As they do not have the raised section as used by the 75/76F, they will have a slightly lower compression ratio . This is not really a big thing as the difference is only 9.2 vs 9.0.
They also have the 3-piece oil ring which is better than the single piece oil ring type.
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
« Reply #4 on: October 05, 2008, 04:49:20 PM »
its best to take a look inside first, also if the pistons are over sized then a re-bore is required.
82' C90
87' yamaha T80
82' CB650z
92' Suzuki GSXR600
80' CB250N
Offline bunghole
« Reply #5 on: October 05, 2008, 05:00:06 PM »
Not to turn this in a parts for sale hijack, but I have my stock pistons if anyone wants them.  They were within spec when I tore the engine down to go to 836.
If you pay for shipping, I'll get them to you and then you can pay me what you think they're worth.  And if you think they're worth nothing, that's cool too.
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
« Reply #6 on: October 05, 2008, 10:38:50 PM »
If you have to spend your money on a rebore and a piston kit why not do a 836 rebore and not a 1st over??
  • I'm not really a
  • 1976 750 F
« Reply #7 on: October 06, 2008, 07:10:32 PM »
Disclaimer-  I'm an engine neophyte, please correct me if I'm wrong.
It's my understanding that just from the mileage I may be looking at cylinders that are worn enough that they'll need to go oversize (I've put over 20k on since owning it).
I'd like to avoid both the retuning that seems everyone goes through with an 836 and the slippery slope that I know I'll partake in (well, if i'm going 836, I should port to get the best out of it, new cam, etc).
What is the chances that I only need new rings and a light hone?
spwg
« Reply #8 on: October 06, 2008, 07:24:13 PM »
Only way to know is to measure. It is very possible to just hone and re-ring. Did you mention mileage? Have you been running the crap outta it like some of us do? I've put 20K+ HARD miles on my 810 kit and it uses no oil BUT like yours it blows oil on my pants (I don't consider that using oil). I have honed and installed new rings. Yes, my head gasket has a slight leak but I really think the blowing oil is coming from the o-ring pucks under the cam towers.
  • I'm not really a
  • 1976 750 F
« Reply #9 on: October 06, 2008, 07:33:01 PM »
Unfortunately, I don't know the mileage.  The clocks weren't original when I got the bike.
I'm not burning oil, at least in a substantial amount.  Compression is in the 120-130 range across cylinders (2 at ~125, 1 at ~120 1 at ~130).
spwg
Offline Clyde
« Reply #10 on: October 06, 2008, 11:02:20 PM »
Honda cylinders are very good and tend to last a long time.
You will only know for sure when you pull the engine down, but therer is a good chance a light hone to remove any glaze and a new set of rings will give the engine a new lease of life.
At the same time you should do the valve seats as they can also make a difference.
SOHC4 #1909
