Author Topic: cylinder head milling 75 750 f  (Read 718 times)
750mikeb
« on: October 10, 2008, 05:03:47 AM »
I was wondering how much I can mill off my cylinder head it is being reground is 10 thousandths too much? I would like to straighten it and increase the compression also thanks   mike
Re: cylinder head milling 75 750 f
« Reply #1 on: October 10, 2008, 05:32:17 AM »
.010 is not to much. I'd recommend you install a slotted cam chain sprocket too.
Offline johnny_from_bel
  • Member #158
« Reply #2 on: October 10, 2008, 06:25:25 AM »
The manual says to rework the head if it is more than 0.25 mm wraped (diff between highesd and lowesd point)
So I take you can safely shave off 0.25 mm
