Author Topic: tach and speedo ratios for cb550  (Read 12131 times)
jon44
« on: October 13, 2008, 06:11:27 PM »
Does anyone know what the ratios for a tach and a speedometer on a 76 cb550 are?
thanks
Offline Clyde
Re: tach and speedo ratios for cb550
« Reply #1 on: October 13, 2008, 07:22:20 PM »
The tacho is 20:3 or 6.67. The 350/400/500/550 are all the same. The CB750 is 4:1
In the case of the 550 - 10,000 rpm at the crankshaft means the cable turns at 1500rpm and the tacho reads 10,000.
Most honda tachos are driven from the camshaft which turns at 1/2 crankshaft speed. Thus there is inherently a 2:1 ratio anyway and the difference is through the tacho drive gears
The speedo is 2240rpm (at the cable) =60mph (or 1400rpm = 60kph)
Most speedos of the time were the same (Honda, Suzuki Yamaha,etc) and also a lot of newer speedos.
Providing you use the original speedo drive on the wheel it will not matter whether you use a 16 or 19 inch wheel-it should still read the correct speed.
Where problems occur is when the rim is changed for a different size to the original for that wheel/speedo drive
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
jon44
« Reply #2 on: October 13, 2008, 10:17:29 PM »
Thats great news.  Thanks.  I can now purchase these mini guages i've been looking at.  drag specialties makes them.  it seemed by everything i read that 2:1 was a harley ratio but thanks to you now i know that i can get it.  and the 2:1 mechanical tach is cheaper than the other ones for some reason so yeah me.  Thanks again
jon
Offline Clyde
« Reply #3 on: October 14, 2008, 06:51:45 PM »
Jon,
Sorry if I misled you. The tacho ratio is 6.67:1 for your bike. not 2:1.
The tacho drive gears that I was referring to are in the head and combine with the camshaft rotating at half engine crank speed to give a 6.67:1 ratio
2:1 will not work
SOHC4 #1909
jon44
« Reply #4 on: October 14, 2008, 08:11:06 PM »
do you know of any mini gauge tachs that are 6.67:1?  Looking and not really coming up with anything.  The only thing I can find is on this japanese chopper website that says that most hondas up to 550cc's are 7:1.  Is this close enough or totally not ok?  And of course, thanks
« Last Edit: October 14, 2008, 08:25:46 PM by jon44 »
Offline Clyde
« Reply #5 on: October 15, 2008, 12:08:53 AM »
Most people round it of at 7:1 and yes it is close enough.
6.7 to 7 is only about 5% different.  Most tachos are only as accurate as 10% anyway, from what my speedo man tells me.
SOHC4 #1909
jon44
« Reply #6 on: October 15, 2008, 11:52:52 AM »
Thanks for all your help.
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #7 on: October 15, 2008, 12:16:13 PM »
Sorry if this is a stupid question, but what are some sources for a tachometer? The one on my 550 is a 750 tach, thanks to TT for pointing it out, but now my problem is replacing it with a more accurate tachometer.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
jon44
« Reply #8 on: October 15, 2008, 09:10:47 PM »
Well this is the one that i'm getting.  It is here. http://crc2onlinecatalog.com/chopper.htm
Offline jcorrill
    • Elite School of Wrestling
« Reply #9 on: June 02, 2014, 08:04:22 AM »
So the speedo needs to be 2240 = 60mph  &  the speedo needs to be 7:1  or are the both 7:1?
Nothing will test your patience like owning a vintage motorcycle.
