Author Topic: CB550F - Tricks / Tips To Mount Carbs  (Read 1769 times)
m-cman
« on: October 15, 2008, 06:47:46 PM »
I have a 1975 CB550F and just rebuilt the carbs.  However, I am having a terrible time getting them back on the bike.  Are there any tips or tricks to doing this? I've gone so far as removing the air box but that presents more problems in installation.  Please help!!!   ???
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
Re: CB550F - Tricks / Tips To Mount Carbs
« Reply #1 on: October 15, 2008, 06:57:10 PM »
Without new, soft carb insulators, I've used some silicone lubricant on the boots and carbs, and pulled them on using a large pair of slipjoint pliers.  A band clamp also works well too.
spwg
Offline mkramer1121
« Reply #2 on: October 15, 2008, 07:11:48 PM »
Air box should be removed.  Have 2 insulators on the carbs and 2 on the engine.  Should go on fairly easy.
As for reinstalling the airbox, have the intake taken off of the box.  mount the intake w/ rubbers on the carbs, then reinsert the box in frame and bolt it up.
Offline Mule Train
« Reply #3 on: October 15, 2008, 10:23:57 PM »
also you can use a hair dryer and heat up the boots to soften them a bit, but really take the boots off the bike and mount them on the carbs then back on to the motor
robermcm
« Reply #4 on: October 16, 2008, 04:53:37 PM »
There has to be a Honda shop trick to remounting.  My 75 cb550k took over an hour, I bent up the clamps and wanted to break something just to stop the frustration!  I need to remove them this winter and was thinking that maybe I'd get some advantage in removing the four cast ports bolted to the head.  If they can slide on without much left/right wiggling, then you could mount to the airbox and bolt the ports to the head as the last step.
Dunno, wouldn't mind an ex Honda mechanic to chime in on this.
« Reply #5 on: October 16, 2008, 05:19:09 PM »
I've written up the removal and installation procedure several times in past threads for the 550.
High points...
1.  The rear band clamps get removed completely during install/removal.
2.  The filter box and air plenum do NOT get removed.  However, the filter box mount bolts do get removed allowing bother the filter and the air plenum to move back against the frame.
You will need to avail yourself of the rear couplers compliance during carb movement.  Hardened ones make this far more chalenging, however the stiffness of the band clamps makes this way difficult.  That's why you remove them.
You use the rear face of the front couplers as a bearing surface while moving the carb bank.  Doesn't hurt to have some silicone spray to ease movement.
Watch out for snags on the rear couplers to avoid tearing them.  A right angle scribe with the point dulled helps move the rear couplers where they cause hang-ups.
I can remove and install a carb bank in the time it took to write this up.  (I do type slow, though.)  There is still some wrestling.  But, it is methodically forthright.
m-cman
« Reply #6 on: October 17, 2008, 12:26:41 PM »
TwoTired,
I did several searches and couldn't find your writeup.  Could you post a link or ? so I can copy and print the total procedure? I am still having problems. Thanks.
« Reply #7 on: October 17, 2008, 02:07:43 PM »
m-cman
« Reply #8 on: October 17, 2008, 08:57:47 PM »
Thanks for the info.  Will give it a try over the weekend.
Offline crazypj
  • I'm brill, me
« Reply #9 on: October 17, 2008, 10:21:15 PM »
I'm 'former' Honda mechanic
 I get the feeling they just built the frame around the engine  ;D
 The only way I know is same as Twotired described
PJ
KingCustomCycles.com
« Reply #10 on: October 18, 2008, 03:53:07 AM »
High points...
+1 with the additional comment that you may be able to work from inside the airbox to shove the couplers out and into their grooves.  I would estimate there are easily 100 tips and tricks to doing Honda carb installs and I have used many.  I may take the time to write them all when the snow falls here.  Right now my shop is overflowing, I just got married, and my professor job is ramping up.  Stay tuned.
« Reply #11 on: October 18, 2008, 09:16:39 AM »
The Cb550 couplers are glued into the air plenum by the factory.  They aren't *supposed* to be removable.  However, if you do a gorilla imitation, they *will* come out. ::)
m-cman
« Reply #12 on: October 19, 2008, 09:51:32 PM »
Thanks to all for the responses. Right now I need a few carb parts.  All for stock 1975 CB550F carbs. I need a #3 (left to right while sitting on the bike) carb float bowl (broke the overflow tube at the inside base  :-[ ). Also need some of those springs that keep the main jet from falling out. What are they called anyway?
Is there a source for these parts? None on eBay right now.
Thanks again...
Offline jason teamshralp
« Reply #13 on: October 20, 2008, 12:05:48 AM »
I seem to only be able to get my carbs in from the right side of the bike. They for some reason will not go in from the left. Just my 2 cents. so make sure to try each side.
Offline Deltarider
« Reply #14 on: October 20, 2008, 07:32:58 AM »
+1
CB500K2-ED Excel black
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #15 on: October 20, 2008, 07:50:15 AM »
I've put TT's instructions in the Carb FAQ.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
