Check this out!
Use coupon code "handheld10" during checkout.
Save gas these days, it says 100~150mpg mile per gallon.
link to 50cc for $112.50 with coupon-
http://www.handhelditems.com/certified-motorized-bicycle-engine-50cc-p-18865.htmllink to 80cc For $125.99 with coupon-
http://www.handhelditems.com/certified-motorized-bicycle-engine-80cc-p-18864.htmlThis kit comes with every thing that you'll need to convert bicycle into a motorized bike
You'll still be able to pedal the bike and ride like normal or start the engine by releasing the clutch lever. There's no rope pulling needed. You can stop or start the engine as you ride.
5-6 HP (horse power)
25 to 40 mph depending on the gear ratio and weight.
MPG 100-150 miles per gallon.
Independent drive sprocket and chain that does not interfere with your current drive chain or peddling.
The engine kit only adds about 20 lbs to your bike.
All Black Alloy Clutch
Better Quality
EPA Certified (black exhaust pipe)
Bicycle is not included
*This kit will fit most V-frame bikes. HandHelditems does not guarantee this will fit all bikes.
Shipping Weight: 25 LB
