Author Topic: Will 1972 HONDA CL450 fork tubes fit a 74 550K  (Read 1488 times)
Tattoo
« on: November 16, 2008, 01:26:14 PM »
Will 1972 HONDA CL450 fork tubes fit a 74 550K? All I need is the tubes my lower legs are real nice. If not what years and models will fit. I'm trying to get rid of the 6 over front end. Tattoo
Re: Will 1972 HONDA CL450 fork tubes fit a 74 550K
« Reply #1 on: November 16, 2008, 10:08:37 PM »
I know the 70 CB 450 will fit  on a 750, but is about 3/4 inch or so shorter, probably lighter springs.. so I would say You can use them on a 500/550...
 Just remembered 750 forks changed after 72, so not sure about yours.. if 3 bolts hold the caliper bracket, they probably have different style tubes internally than the  72 tubes....
« Last Edit: November 16, 2008, 10:11:34 PM by 754 »
« Reply #2 on: November 17, 2008, 02:19:00 AM »
Yes ,physicaly but the dampers wont work right as the 450 has no bush welded into the bottom
