Author Topic: Should the back tire touch the ground when you're on the center stand?  (Read 5116 times)
Offline DORIGTT
I've always thought that the back tire was supposed to spin free when my CB750 is on the center stand. It completely touches the ground.  Is this normal?
Offline BlindJoe
Re: Should the back tire touch the ground when you're on the center stand?
« Reply #1 on: October 21, 2008, 09:41:00 PM »
Nope
ev0lution7
« Reply #2 on: October 21, 2008, 11:19:40 PM »
no the back tire should be up in the air not touching the ground check your shock heights and your fork heights they are prol off
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #3 on: October 21, 2008, 11:29:41 PM »
Try pointing it down if you are on a "very" slight slope. Otherwise use a sliver of plywood under stand and all will be well. ;D
That's how I deal with it.
« Reply #4 on: October 21, 2008, 11:59:03 PM »
I'm betting you've got longer rear shocks fitted, (lots of "Cafe" guys fitted those crappy CB900 units with the remote reservoirs that are an inch or so longer than stock CB750's) or conversely, you've got longer "Chopper" front forks. Cheers, Terry. ;D
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #5 on: October 22, 2008, 03:53:55 AM »
Check the frame cross tube that the centerstand mounts to. I have had the same problem and it was due to the cross tube being cracked(usually where it is welded to the frame). The center stand could be bent also.
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
KingCustomCycles.com
« Reply #6 on: October 22, 2008, 03:56:13 AM »
+1 happened to me 2 days ago on a customers street  ::)Yamaha.  Shocks were some sort of longer off road abomination.  The side stand was too short also then and it caused the float bowl to overflow due to the angle. The thing was kick only and hadn't run in years.  Boy do I not miss those days.
« Reply #7 on: October 22, 2008, 03:57:20 AM »
Good morning, your frame is cracked, could you let him get his coffee first? ;D
Offline goon 1492
  • Sucka Repellant
« Reply #8 on: October 22, 2008, 06:48:16 AM »
 :'( :'( :-* :-* ::) ;D ;D ;D ;D ;D ;D ;D
Offline bikerboycb650
  • And YOU must be the Monopoly guy!
« Reply #9 on: October 22, 2008, 06:52:27 AM »
Is there a "secret" to getting it on the center stand easily? I always have a tuff time, and I'm a pretty strong guy.
upperlake04
« Reply #10 on: October 22, 2008, 07:04:40 AM »
 If your tires are taller than stock specs, this would happen also.
Offline heffay
« Reply #11 on: October 22, 2008, 07:08:43 AM »
how about a picture so its not a big guessing game.
Offline 333
  • Time for change
« Reply #12 on: October 22, 2008, 07:35:52 AM »
Yes.  Left hand on left handlebar.  Right hand on grab bar.  With your right foot. push centerstand to the ground and adjust the stance of the bike so it sits evenly on both feet.  Here's where most people try to lift the bike up.  And there is a fine line between this and the easier way.  The idea is to "spread apart" the distance between the centerstand and the grab bar.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline heffay
« Reply #13 on: October 22, 2008, 07:39:08 AM »
yes, i'll go one step further and say to consider yourself as a lever, prying the rear of the bike and the centerstand apart... you're not a jack trying to lift up the rear end alone.   ;D  really standing (putting considerable weight) on the centerstand tang helps alot.
Offline goon 1492
  • Sucka Repellant
« Reply #14 on: October 22, 2008, 09:20:07 AM »
+1 on his comments that is exactly how i did it last night.....
« Reply #15 on: October 22, 2008, 09:45:34 AM »
AHHHH... I took the grab bar/Sissy bar off! No wonder!
Offline coyotecowboy
  • Easily Distracted
    • American Legion Riders Post 69 Medicine Lodge, Ks
« Reply #16 on: October 22, 2008, 10:43:30 AM »
Put your right knee against the shock and use it for leverage while you're pushing down on the centerstand.  I just use the grab bar to steady the bike.
The adventure begins when things stop going as planned - Glen Heggstad
http://www.alrpost69.com/
Sunrise Orange 750 K2
1981 Husqvarna 430 XC, "Inga"
« Reply #17 on: October 22, 2008, 01:12:05 PM »
Ok, do you guys use the Center stand always? Like when u park it to go to work?
  • Easily Distracted
« Reply #18 on: October 22, 2008, 05:43:17 PM »
I use mine when I have to work on the rear of the bike (oil chain, pull swingarm, yadda yadda..)  The rest of the time the heavy SOB leans in the corner of my shop ;)
« Reply #19 on: October 22, 2008, 05:48:27 PM »
My K0 is an absolute motherrfcuker to get off the centre stand. Dunno why, the frame is fine, but the stand seems to go too far forward?
I must take it off one day and try to work out what's wrong with it, but if I use it the wheel is still off the ground, I just need my son to give me a hand to get it off the stand after I do the chain adjustment or whatever. Cheers, Terry. ;D
  • Easily Distracted
« Reply #20 on: October 22, 2008, 05:54:24 PM »
I remember reading that the 69-70's were easier to get ON the stand and harder to get off, Honda did a redesign and the 71's-on were harder to get on the stand, but easier to get off.
I know my K2 has to be sitting on fairly level ground or you'll give yourself a hernia getting it on the stand.  It always comes off easy though.  Just grab the handlebars and give it a little push.
« Reply #21 on: October 22, 2008, 06:41:42 PM »
That might be it mate, the K0 is easy to get on the stand, but a bugger to get off. Cheers, Terry. ;D
« Reply #22 on: October 23, 2008, 10:47:33 AM »
Hmm, yeah once I get my 81 on, its really easy to get off.
Offline edbikerii
    • Gallery
« Reply #23 on: October 23, 2008, 09:51:56 PM »
My GL1200 had the same problems, rear wheel on the ground when on stand, pretty hard to get it up on the center stand, and nearly impossible to get it off the center stand.
I looked at the top of the centerstand, and noted that the spots where it touched the frame were bent in quite a bit over the years with that 850lb. bike.
So, I found a 3/16" piece of steel, cut it to fit the top of the centerstand, and MIG welded it in place.  Now all three problems are solved.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline DORIGTT
« Reply #24 on: November 20, 2008, 11:19:58 PM »
Found the problem...
I asked my mother (the original owner of the bike by the way) if she modified the forks and she told me she got 10" longer front forks.
Problem solved.
