Author Topic: PISTONS (970cc? 1000cc?)  (Read 61682 times)
Offline Big Jay
    • CBRzone
Re: PISTONS
« Reply #25 on: October 29, 2008, 10:14:41 PM »
Going to do 10:1. Don't thing anyone would want higher than that.
Jay
Re: PISTONS
« Reply #26 on: October 29, 2008, 10:33:17 PM »
Is not 10.5 what most kits were in the old days?
I was thinking if I could get 12:1, that I would modify to about 11:1, seeing as I never had any  problems even with regular gas..
Jay, any idea of pricing on these units?
Also, did APE ever make the main bearing studs for the CB 750 engines.. would like to run a set of them..
Re: PISTONS
« Reply #27 on: October 30, 2008, 04:49:49 AM »
Dynoman sells main bearing studs. I believe Jay makes them for him.
Re: PISTONS
« Reply #28 on: October 30, 2008, 05:05:56 AM »
Jay
I think that is a good number. By the time you get done decking and milling you'll add 1/2 point.
Re: PISTONS (970cc? 1000cc?)
« Reply #29 on: October 30, 2008, 07:50:35 AM »
Thanks Steve ;) ;) ;)
Sam.  ;)
« Reply #30 on: October 30, 2008, 08:44:02 AM »
 OK. Who is in on a 1000cc kit? I'll be the first to say I'll take one (as long as it comes with a modern head gasket).
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #31 on: October 30, 2008, 09:07:48 AM »
Can this be done with machining->welding->machining->resleeving->boring the stock block or what's the story?  ;D
« Reply #32 on: October 30, 2008, 09:15:29 AM »
It is to laugh, pardon me.  ;)  All giggling aside, its a process, but one which a motivated person can accomplish. One must press out the stock sleeves, bor the alum block, press in new sleeves, bore them to the pistons. Also, I'm guesing the cyl studs will be removed (you'll want to upgrade anyway) and bore the top crankcase to accept the new sleeves.
I have run and will run again an 888cc kit. Same process except the bottom of the sleeves are tapered bypassing the boring of the crankcase. I think 888cc is the largest that this will work on.
But at 1000cc you'll need / want rods, lightened crank, maybe tranny work, so its a complete teardown to the last nth, but oh what results. About on par with a mid range modern 600cc sportbike. But we love our CBs.
Offline Leino
  • Not much of an
« Reply #33 on: October 30, 2008, 09:20:39 AM »
Well... those are the facts I already knew, and I have the lightened/balanced crank, undercut transmission etc. etc. on my 836cc at the moment.
I was just curious about the cylinder block, and if this could be done with the stock block
re-sleeved etc.
Juha
« Reply #34 on: October 30, 2008, 09:25:19 AM »
re-sleeved etc.
Juha
Great, that's a cool motor!  And yes, you just resleeve the stock block and bore the crankcase. FYI: There is no aluminum left between 1-2 and 3-4 after the boring! But no welding or oddball machining need be done.
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« Reply #35 on: October 30, 2008, 10:05:17 AM »
Rebalancing required with the new 1000cc pistons?
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
« Reply #36 on: October 30, 2008, 11:14:54 AM »
You may want to hear from a real engine builder, but my take is, the 4 cylinder crank config is "neutral" so any displacement does not "require" a rebalance. However, the crank is balanced at the factory to rather loose average specs. A stock motor would benefit from a better balance, and a bigger motor that much more in terms of smoothness. And smoothness goes to reliability etc. The psitons are balanced to each other as are the rods.
So while you're at it, take off some pounds on the crank itself and off the alternator. That weight is masking the loose tolerances on the factory balance, a cheap substitute for smoothness..  That will allow that extra displacement to really cook. And lightening would require rebalancing.
Comments?
« Reply #37 on: October 30, 2008, 12:55:25 PM »
I can't let Mike out-do me so I'm in for the 1000 kit but we also need the base gasket too.
« Reply #38 on: October 30, 2008, 02:08:58 PM »
Jerry....I don't think I could ever out-do you. ;) ;D Yes on the base gasket....preferably in .010 thickness.
fuzzybutt
« Reply #39 on: October 30, 2008, 03:56:32 PM »
i was at Metalheads this past weekend and i know he'll be up for a 1000cc kit
« Reply #40 on: October 30, 2008, 04:29:03 PM »
No one has mentioned the price yet, pistons apart, what price for the ready to go block?
Sam. ;) ;)
« Reply #41 on: October 30, 2008, 07:24:41 PM »
I'd bet that your head will yield 2 or 3 hp more than the one you will have to build for me  ;)  :D
« Reply #42 on: October 30, 2008, 07:26:30 PM »
The gauntlet has been thrown.....you are on bro!
« Reply #43 on: October 30, 2008, 07:31:27 PM »
OK.....2 sets of 1000cc. Who else is in?
« Reply #44 on: October 30, 2008, 08:07:10 PM »
Need price.. and shipping costs...
« Reply #45 on: October 30, 2008, 08:16:49 PM »
I understand that. I wonder......could something else be worked out. ;) ;)
Offline Big Jay
    • CBRzone
« Reply #46 on: October 30, 2008, 09:21:30 PM »
I will get the tentative pricing worked out and posted.
As for rebalancing the crank, not necessary. Inline four cylinder cranks are "self canceling", so as long as the components all weigh the same, it doesn't effect the balance..
Jay
P.S. Thanks to whoever got the sticky done.
« Reply #47 on: October 30, 2008, 09:49:23 PM »
Twas I that pushed it but, we can talk big discounts at a later date,  :D :D :D hope your contingency pay outs apply to bracket racers as well
Sam ;)
Offline mec
« Reply #48 on: October 31, 2008, 01:52:18 AM »
hi,
I did my experience with 1000ccm pistons (rc eng) in the late 70ies.
I remember there had been issues with oilleakage using the stock cyl-block.
boring the block, there will be huge "windows" between 1/2 and 3/4 and the sleeves become visible. those days I sealed these holes with "devcon". that solved the proble. however, there had been other "invisible" oilleakages round the sleeves cause of the very thin cylinder wall (during riding my boots took a hot oil bath :))
curious how will you solve these problems?
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline KB02
« Reply #49 on: October 31, 2008, 05:19:30 AM »
Mike, you are like a kid in a candy store.   ;D ;D ;D ;D ;D
I'd love one, but I've gt to get my 850 together and ridable before I can even think about another engine.
okay, that's not true... I've been thinking, I just can't do anything about it yet.  :-[ ;)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
