Author Topic: Polishing  (Read 1655 times)
Offline Johnny5
    • CB350F build thread
Polishing
« on: October 23, 2008, 09:55:07 AM »
Im looking into the equipment I'll need to polish my valve cover, engine side covers, ect. Im going to get a double wheel (dont know the proper name for the tool) but it'll have a polishing wheel on one side and another on the other. My question is, can I install and very light wire wheel on this side to take out scratches in the metal? Im thinking it might be too harsh. So what can I use to take out scratches? Is sanding the only option?
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline unkle fester
Re: Polishing
« Reply #1 on: October 23, 2008, 10:10:49 AM »
Offline mystic_1
  • 1970 CB750K
Re: Polishing
« Reply #2 on: October 23, 2008, 10:12:44 AM »
That's called a "polishing machine"  :)
Do NOT use a wire wheel on aluminum.  Aside from anecdotal evidence that steel brushes will embed steel particles into the aluminum which will then rust, there's the fact that wire wheels put IN scratches.  Lots of them.  Very quickly.  You get a crappy finish then because the surface isn't truly flat any more.
A spiral buff with a course compound will remove light scratches.  For deeper scratches, wetsand.  Starting grit for sanding will depend on depth of scratches/gouges, I like to start around 400 and work my way down to 1000 or so.  Then back to the wheel to finish it off.
mystic_1
- John Augustus Shedd
Offline Johnny5
Re: Polishing
« Reply #3 on: October 23, 2008, 10:21:20 AM »
mystic_1
Awesome, thanks. Cant wait to start.
1971 CB350
1973 CB350F
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
Re: Polishing
« Reply #4 on: October 23, 2008, 12:30:49 PM »
If I could swing it I would have ya send the stuff to me here at work to have it polished ->
We have the largest polishing houses in the country !
Offline Johnny5
Re: Polishing
« Reply #5 on: October 23, 2008, 12:38:15 PM »
Im really all about doing as much of the work myself when Im able. I like learning and whenever I can get a new tool, then that's a bonus.
Will certainly keep you in mind.
1971 CB350
1973 CB350F
Offline bunghole
Re: Polishing
« Reply #6 on: October 23, 2008, 12:54:04 PM »
I've gotten kind of lazy about my polishing and I just go straight to the spiral wheel with emery compound.  I've found that by using some heavy pressure and building up some heat, I can take out all but the worst scratches.  It isn't as perfect as sanding first, but I like the results.
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline Really?
Re: Polishing
« Reply #7 on: October 23, 2008, 07:00:36 PM »
I usually do a 320, 600, 1200, 1500 and then 2000 (all wet).  Then mothers with my dremel and a buffing wheel on it about three times.  To me, it comes out perty darn good and it does not take too long either.
When I have to go back it is 2000 wet and the dremel with mothers and the buffing wheel.
Tried the rouge kit from home depot.  I could not get it to work.  So, I stick to the other way.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Steve F
Re: Polishing
« Reply #8 on: October 25, 2008, 07:53:19 PM »
I like using the NORTON BearTex wheels to get everything even and smoothed and remove the scratches.  Then I follow with the red compound ont eh spiral stiched wheel and then the white compound on the linen wheel.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: Polishing
« Reply #9 on: October 25, 2008, 11:03:52 PM »
Gees, I just strap the neighbors cat to my elect drill and have at er
Offline Steve F
Re: Polishing
« Reply #10 on: October 26, 2008, 12:09:36 PM »
I thought you wanted to get RID of the scratches  :D  :D Good use of a cat though!
Offline Johnny5
Re: Polishing
« Reply #11 on: October 27, 2008, 11:52:27 AM »
Well, you have to declaw the cat first. Vice grips have more uses than just stripped bolts!
1971 CB350
1973 CB350F
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: Polishing
« Reply #12 on: October 31, 2008, 08:04:29 AM »
On most aluminum, I go 600 grit sandpaper, then red buffing commpound on a buffing wheel, then white buffing compound. I try not to spend too much time on any one piece. With each piece looking 3 or 4 times better than stock, even imperfect polishing on EVERYTHING looks a lot better than stock.
If there are heavy scratches or a lot of oxidization, I'll use a 350 or 300 grit gently to clear that stuff away first.
This is only an hour or so of polishing. The pictures really dont do the reflectivity justice, actually. The engine looks twice as good in person.
No.
Offline Really?
Re: Polishing
« Reply #13 on: October 31, 2008, 09:47:20 AM »
The pics below give you and idea of what mine turn out like.  I did not spend a lot of time on them really and did them on the bike.  The polished pic does not give the polish justice but you get the idea between the two.  It was perty nasty before I started on it.  That was 30 minutes after I got it home and toke of the big highway fairing, trunk rack and hiway bars.
