Author Topic: Simple Question: Where does the main ground wire connect? '78 cb750  (Read 3060 times)
Offline Kev Nemo
  • Honda Hacker
  • http://fallingapartart.com/
    • FallingApartArt
putting it back together and forgot where this was mounted??
Destroyed by Design since 2009 http://fallingapartart.com/
- '78 CB750k bobtrack
Offline Steve F
Re: Simple Question: Where does the main ground wire connect? '78 cb750
« Reply #1 on: October 23, 2008, 12:56:28 PM »
Well, on a '76 750F, the end with the large "O" lug, squeezes in between the engine and the frame, on the right side by the upper-rear engine mount bolt.
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #2 on: October 23, 2008, 08:29:51 PM »
same deal on 78 K's
be sure to clean up the area it is mounting for best connection.
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #3 on: October 24, 2008, 07:08:47 AM »
got it-thanks!
Offline heffay
« Reply #4 on: October 24, 2008, 07:18:24 AM »
anywhere you want it to w/ exposed metal not insulated from the engine or other grounded parts.   ;)   ;D
