Author Topic: 1975 Honda CB125s - possible carburetor problem  (Read 4025 times)
chriscraft42
« on: October 25, 2008, 01:09:32 PM »
My bike has been acting really strange lately and I can't seem to figure what the problem is. First it has been a little difficult starting but when started needs to be at a high idle (2200 rpm)or it will stall. When I finally start to ride it runs fine until I come to a stop and then the bike stalls. I replaced the slow jet which someone recommended by I am still having a problem. I also have adjusted the air and idle screws to get it to idle correctly but it doesn't help...any suggestions...thanks
Offline scunny
  • don't call me expert
Re: 1975 Honda CB125s - possible carburetor problem
« Reply #1 on: October 25, 2008, 01:28:44 PM »
pull the carb and clean all the passages and jets
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #2 on: October 25, 2008, 02:20:34 PM »
also check for intake leaks.
No.
KingCustomCycles.com
« Reply #3 on: October 25, 2008, 02:21:52 PM »
Yep, classic symptoms of an induction air leak or other sudden lean condition.  Spray wd40 around to find your leak. (that is all it is good for except scuffs on my kitchen floor)  If none show up, it is internal like a plugged carb jet or valves.  See post above.
« Last Edit: October 26, 2008, 02:44:30 AM by KingCustomCycles.com »
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #4 on: October 25, 2008, 07:56:51 PM »
Could be carb, timing, valve adjustment, .........a good overall tuneup rules out a major problem.
...But I've got an CB125S which acted the same way. Would not idle at all and the lowest I could get it too was about 2000 rpm. Ran it for a little while then the problem got much worse.....Turns out a piston ring was broken all along.
Won't run without a lot of noise now  :D
Try a tune up, but that didn't fix mine.
 Matt.
Gallery at:
