Author Topic: what's the deal with my front forks?  (Read 5331 times)
Offline JP74
  • "i'll be at the garage"
  • always more work do...
« on: October 27, 2008, 10:22:46 AM »
so after looking at photos upon photos of other bikes, i realize that theres something not to normal or stock about my front forks. they are alot longer then what i see on every other 750.
looks like the PO was going for a chopper look (see 2nd pic). after i drained and refilled the forks according to the manual, the height actually increased by about an inch(1st pic is how it sits now)...
when i had the caps off the forks to refill there was a metal tube/pipe maybe 5in in length installed on top of the spring... since that was the 1st time i had messed with anything suspension wise, i didn't know what was normal and what was not....
now that i have thought about it more, i wonder if the PO had installed these tube/pipes as a makeshift way to have extended forks for the chopper look... want to get some input before i just go out and remove them, since I'm not sure if they are supposed to be there...
any thoughts?
PS. the fork brace is a bolt on
~1976 750k~
« Last Edit: October 27, 2008, 10:28:49 AM by The.plastikfork.killer »
76-cb750k, 75-cb360T, 71-cb750k,
73-cb750 AMEN hardtail,
78-750k roller..cl350..cl450. kz400,gs750.  maybe more
Offline pablo78cb550
  • mmmph.
Re: what's the deal with my front forks?
« Reply #1 on: October 27, 2008, 10:42:46 AM »
5" extended fork tubes with original springs and spacers.
thats what I'm guessing.
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #2 on: October 27, 2008, 10:59:57 AM »
 Yup, thats what we used to call a semi-chopper.
Cut those things down and you will find cornering a lot nicer.
Bikes parked out front mean good chicken-fried steak inside.
Offline JP74
« Reply #3 on: October 27, 2008, 11:16:23 AM »
so i am probably looking at needing new forks to drop it down huh?  they would most likely be extended fork tube if they have those tube/bars in them right?
Offline Really?
« Reply #4 on: October 27, 2008, 11:19:13 AM »
Replace the tubes, and then toss the tubes in the tubes and the fork brace.  Springs might just be normal.  Check to see if they have been cut - decide what you want to do with the springs, keep em or replace em.
Then you will be stock or perty darn close.
CycleX I think has stock tubes.  Ebay should too.
CycleX also has -2 shorter but you will need to cut the springs to fit - this is if you want to drop it further than stock and further than about an inch (tubes slide up the trees).
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« Reply #5 on: October 27, 2008, 11:28:06 AM »
Mine were 6" longer, I bought stock length tubes from "Forking by Frank". You could cut down the fork tubes you have now, a simple lathe job although the caps have an uncommon thread.
You also have lowering blocks in the rear.
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
Offline JP74
« Reply #6 on: October 27, 2008, 11:50:39 AM »
Thanks to all of you guys for the info and help..
rear lowering bocks??... really?
Offline Johnny5
    • CB350F build thread
« Reply #7 on: October 27, 2008, 11:58:25 AM »
Yep, check the bottom of your rear shock. That black block isnt stock. And Im not Dr. Suess....
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline UnCrash
  • Pass
    • My Blog
« Reply #8 on: October 27, 2008, 12:05:24 PM »
Good eye Johnny.
Those sure do look like lowering blocks.  Getting rid of them, and finding replacement tubes will make your ride much, much sweeter.
Ask around here, many of us have this kind of thing collecting dust on a shelf.
Offline Really?
« Reply #9 on: October 27, 2008, 12:27:01 PM »
You might need to replace that kickstand too.  Might be too long when you bring the tubes back down to normal.
Offline Artfrombama
  • CB750 K2
« Reply #10 on: October 27, 2008, 01:07:07 PM »
Yep, I've got a "holed" generator cover for trying to use the chopper side stand with standard length forks. :(
« Last Edit: October 27, 2008, 01:08:41 PM by Artfrombama »
Halfassed machinist
CB750E2441103
Offline shoemanII
  • just another bike nut
« Reply #11 on: October 27, 2008, 02:28:30 PM »
if the extended forks are in good shape, the boyz at hondachopper.com will take 'em and someone here will take the lowering blocks.  you're total outlay won't be so bad, but be patient. ;)
bobp
'96 ducati carb'd 900ss/cr
'72 dt2
'77cb550k frankenberry:  '77cb550k frame, '78cb550k engine, '78cb550f tank, unknown front-end
  • mmmph.
« Reply #12 on: October 27, 2008, 02:46:25 PM »
cyclex says the fork tubes are for 73-78 cb750. were the 78 cb550k the same as those...
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha XS400
1978 Honda CB550K
Sold off:
1992 Yamaha FZR600
Offline JP74
« Reply #13 on: October 27, 2008, 07:42:26 PM »
Good eye Johnny.
Good eye indeed Johnny!  i never would have realized that.
i thought the ride on this bike wasn't what it should be, explains alot
good thinking. thanks for the heads up
so looks like i am now in the market for a set of forks, fork springs(depending on if they are cut), kickstand... and need to sell some extended forks and lowering blocks..  can't wait to see how this thing handles after its all said and done.. anyone have a good link or info about what forks will swap out with what?
again, thanks for the help guys.
if anyone is in the need on these forks or blocks., once i get what i need, they'll be up for sale for sure
Offline Joel
« Reply #14 on: October 27, 2008, 07:47:56 PM »
The 400F I bought had the same things done to it.  I've since removed the lowering blocks.  I found a set of stock forks on eBay and am in the process of rebuilding them before I swap them on.  You might also check Craigslist for some 750 forks.
http://www.servicehonda.com/test/index.htm
If you go to the above link and login to their system, you can look up the part number and it will show you what other models used that same part number.
« Last Edit: October 27, 2008, 07:49:31 PM by Joel C »
Offline mrbreeze
  • Not your average
« Reply #15 on: October 27, 2008, 07:54:45 PM »
I had to laugh when I read this post.......It says plastic fork on the avatar and then asks..."whats wrong with my forks?"  My first thought was......."Uhhhhhhh....they're plastic???"
MEMBER # 257
Offline Johnny5
« Reply #16 on: October 27, 2008, 07:57:56 PM »
I might be interested in the blocks. PM sent.
1971 CB350
1973 CB350F
Offline Artfrombama
  • CB750 K2
« Reply #17 on: October 27, 2008, 09:13:08 PM »
Good eye Johnny.
Yeh Johnny has a great eye!
;D ;) 8)
Halfassed machinist
CB750E2441103
« Reply #18 on: October 27, 2008, 10:57:21 PM »
whatever the spacer pipe length is, will be how many inches over thery are.. pretty rare for someone to cut down springs for long forks..
Borrow a set of clip-ons &  remove them handlebars, slide forks up 8 inches, install the clip-ons if you want to see what the ride should be like...
Offline MrZxp
« Reply #19 on: October 28, 2008, 01:06:42 AM »
This gentleman has a set of forks for sale... he doesn't specify which model they are from though unfortunately...
http://forums.sohc4.net/index.php?topic=42379.0
Cheers, Phil
09 Boulevard M90
SOHC4 Member #3336
Offline Really?
« Reply #20 on: October 28, 2008, 05:49:45 AM »
If you do what is in bold, I want pics.  ;)
Offline goon 1492
  • Sucka Repellant
« Reply #21 on: October 28, 2008, 06:56:19 AM »
they'll look like horns! hang some dice off of them ;D 8) ;D ;D
I just installed lowering blocks on the back of mine, its a 76750k also, gotta wait untill I get the whitewall tires back from getting mounted and balanced to really see how it stands
Offline JP74
« Reply #22 on: October 28, 2008, 07:53:45 AM »
Sorry Art!    got to give credit where credit is due, thanks for noticing the lowering blocks! i really had no clue they were on there, for all i knew, that was a stock setup. thanks again
Offline JP74
« Reply #23 on: October 28, 2008, 08:18:45 AM »
so does that mean any forks from a 73-78 750 should work?.
  makes sense.
  haha i might have to do that just for a picture.
thanks for the link. I'll check it out.
so are there any better swap outs for the forks besides stock 750, maybe off a super sport? i was told that a set of forks off a 550 would be an upgrade, didn't make sense to me, any truth to that?. i would like to stay away from aftermarket forks since cost is an issue..
anyone have any forks if good condition laying around they want to sell or trade?. i have extended forks and a couple windshields...
Offline Really?
« Reply #24 on: October 28, 2008, 08:23:37 AM »
I think some people go the gl1100 forks.  What the upgrade is, I am not sure but then I am sure there are many posts on that.
