Author Topic: Leaking Nipples....  (Read 1659 times)
Offline lordmoonpie
    • Moonpie
Leaking Nipples....
« on: October 27, 2008, 10:50:30 AM »
So now I've got your attention....I've got the brakes on, installed and bled. I tightened the bleed nipples on the calipers with a BIG spanner as tight as I dared to and after a few days they are still seeping brake fluid! So, what do I do?!
Can I put something in the bleed hole to stop this like plumbers PTFE tape or do I just get a breaker bar to tighten then things and hope the bleed nipple doesn't sheer? What can I use to seal this that won't contaminate the brake fluid?!
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline mystic_1
  • 1970 CB750K
Re: Leaking Nipples....
« Reply #1 on: October 27, 2008, 10:54:12 AM »
The bleeder screws have a tapered end that mates with the seat in the bleeder port.  If it's leaking, there's a good possibility that either the end of the bleeder screw or the seat in the port is damaged.  Pull the bleeder screw out and take a look.
mystic_1
- John Augustus Shedd
Offline Porscheguy912
  • I'm a Big Shot Ninja.
  • It's MR. Moustache To you SIR!
« Reply #2 on: October 27, 2008, 11:04:37 AM »
I would try new bleeder valves before you tighten these down even more and break them off in the caliper.
If the new valves don't help perhaps the valve seats in your calipers is gouged or screwed up.
But whatever you do, don't break those little buggers off in the the caliper!
If you do, you will become very friendly with the nefarious tool called the "easy out".
And its name is deceiving because there is nothing "easy" about them. Look up posts on here about them. I have needed them along with a torch, and oil and i ended up breaking the caliper trying to get the dang thing out.
And even if you do get the broken valve out, there is no saying that the seat wasn't  messed up before-hand; leaving all that work for naught!
In a nut shell, replace your bleeder valves, if that doesn't work look at the seats. Chances are they are at fault.
AW mystic! you beat me to it!
Current: 1978 CB750F3
Past: 1974 CB550K
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #3 on: October 27, 2008, 11:38:04 AM »
Damn, what a let down... :D...
As far as the actual problem at hand, I say what the others just said... :)
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline jonbuoy
    • My rebuild:
« Reply #4 on: October 27, 2008, 12:34:37 PM »
PTFE doesn't mix well with hydraulic/brake fluid.
Offline lordmoonpie
    • Moonpie
« Reply #5 on: October 27, 2008, 01:51:29 PM »
Thanks guys - I was worried about that. K0 calipers are not that common so I'm praying it's the bleed screw at fault....rats!  ???
Ah well just so you can see what a lovely setup it might be, here's a picture...
1994 Ducati 888 SP5
Offline 333
  • Time for change
« Reply #6 on: October 27, 2008, 02:08:27 PM »
It almost looks like the bleeder isn't seating down enough.  Like it may be the wrong size.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: October 27, 2008, 05:05:21 PM »
May as well get yourself some Speedbleeders.  If they don't solve the problem, you can use them on the replacement caliper.
mystic_1
Offline moham
  • .fnord.
« Reply #8 on: October 27, 2008, 05:18:24 PM »
bleedin' nipples...
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline wrenchmuch
« Reply #9 on: October 27, 2008, 05:42:13 PM »
If that is your setup in the pic is it possible that you didn't remove the cone seat that the steel oil pipe used to seal ? I seem to remember instructions that said to put a finishing nail through the cone from inside the caliper and then pull the cone out . That may be why the nipple seems to be stickin out so far. ;D
CB750K1
CB750K4
« Reply #10 on: October 27, 2008, 07:50:08 PM »
Breast pads and Speed Bleeders.
Offline Hush
« Reply #11 on: October 28, 2008, 02:02:49 AM »
Maternity bra? ;D
« Reply #12 on: October 28, 2008, 05:47:39 AM »
KBC Tools sells c-sinks that are different angles.. I think it is 90 deg you need.. you can recut a dammaged seat by hand holding the c-sink in a drill chuck..
Offline jonbuoy
    • My rebuild:
« Reply #13 on: October 28, 2008, 10:25:27 AM »
Nice setup  :o
Offline lordmoonpie
    • Moonpie
« Reply #14 on: October 28, 2008, 01:00:57 PM »
Yeah I did take out the cones for the original pipes which was a monster job as the calipers were in a poor state. Maybe I should try cutting back the seat a bit? Think I'll try the new bleed nipples first though as a cheaper option. They do seem to sit mighty high up in the thread but they are very very long bleed nipples - torpedos even!  ;D
I have to take the lines off now anyway as I've just got a replacement for my leaky 3 way union half way down the line setup. Sometimes I wish these were nice modern AP calipers that bleed in 5 minutes flat, but hey, where's the fun in that  ;)
I did try breast pads but they aren't hard wearing enough against the cast iron discs. They do help in the wet though....for a while  :D
1994 Ducati 888 SP5
