Author Topic: anyone have pics of an F rear brake m/c setup?  (Read 1292 times)
Offline uwjberg
« on: October 27, 2008, 04:10:38 PM »
i'm putting my rebuild back together, and like an idiot, i didn't take a pic of the way the spring fits on the pedal/lever behind the mounting plate, and my clymer does show squat. anyone have a pic they can share to point me in the right direction?
« Last Edit: October 27, 2008, 04:25:36 PM by uwjberg »
Offline UnCrash
  • Pass
    • My Blog
Re: anyone have pics of an F rear brake m/c setup?
« Reply #1 on: October 27, 2008, 04:55:51 PM »
I don't have much to show.... I just scanned through my 78 750F teardown photos and the only one I came up with is posted below.
I think the other end of the spring connects to a hole right by the end of the brake lever arm.  As you probably know this spring only actuates the brake light...
Hope this helps some-
Best of luck.
Offline 75750SS
  • 75 750F, 2010 Concours ABS
« Reply #2 on: October 27, 2008, 05:07:37 PM »
Here's a closeup of my 75 750F.
Offline ofreen
« Reply #3 on: October 27, 2008, 06:04:52 PM »
1975 CB750F-
Greg
'75 CB750F
Offline uwjberg
« Reply #4 on: October 27, 2008, 07:25:16 PM »
thanks for all of the replies - i hate to be a pain, but does anyone have a shot of the spring behind the mount? not the switch spring, but the thick pedal return spring. i need to figure out where the ends of that one go.
thanks again...
Offline Steve F
« Reply #5 on: October 27, 2008, 07:55:46 PM »
in the last photo that ofreen posted, you can see it as it's hooked over the arm that attaches to the master cyl. plunger, and the other end hooks around the frame tube as shown in the top photo.
Offline uwjberg
« Reply #6 on: October 27, 2008, 09:55:38 PM »
holy cow - thanks for pointing that out.
thanks again for everyone's help...
Offline MrZxp
« Reply #7 on: October 28, 2008, 12:41:16 AM »
From the 77/78 750 Shop Manual...
Cheers, Phil
09 Boulevard M90
SOHC4 Member #3336
Offline MrZxp
« Reply #8 on: October 28, 2008, 12:45:18 AM »
Or, maybe this one is better.... :)
09 Boulevard M90
SOHC4 Member #3336
Offline uwjberg
« Reply #9 on: October 28, 2008, 08:11:33 AM »
now that's the detail missing in my clymer!
thanks!
