Author Topic: One More Chapter in the Epic Story That is "THE PHOENIX"  (Read 65166 times)
Offline mystic_1
  • 1970 CB750K
Re: One More Chapter in the Epic Story That is "THE PHOENIX"
« Reply #75 on: December 23, 2008, 06:40:31 PM »
Solution to the "doesn't go with rest of bike" issue:
Make more twisty stuff to bolt on.   ;D
Brace looks fantastic.
mystic_1
- John Augustus Shedd
« Reply #76 on: December 23, 2008, 07:02:22 PM »
mystic_1
the kick stand is  ;D ...but i didn't do nearly as good as the brace.    and who ever notices a kick stand  ::) :D
edited to add this pic, witch is really old (from the first build thread)
« Last Edit: December 23, 2008, 10:29:19 PM by spikeybike »
Offline Really?
« Reply #77 on: December 23, 2008, 07:31:12 PM »
I would.  i still need to have it shortened, lol.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
« Reply #78 on: December 31, 2008, 05:38:51 PM »
tore apart my head last night to get the valve springs for my new head,
and i was wondering,  does this look like normal wear
the rockers are NOS and the cam is new as well, i think i did about 700-1000 miles on um
and it also seems i have some more carb tuning to do
« Reply #79 on: December 31, 2008, 06:14:57 PM »
Is your cam cover new style (4 shafts) or old style (8 shafts)?
Have you checked for rocker arm shaft cam cover wear?
« Reply #80 on: December 31, 2008, 06:22:46 PM »
old style
yes, i had it bore gauged years ago, it was well within spec, the cam journals look ok as well
i'm only concerned because i haven't seen a new one break in ever , this could all be normal for all i know
« Reply #81 on: January 06, 2009, 07:49:33 PM »
for those that dont know this trick , when lapping valves , mark the seat of the valve with a dry erase marker to check the contact surface. then you know how much to lap
  before
  after
 got my cam degreed in , but i did it kinda half assed (but not really)
once i figured out were true TDC was, set the valve at .040" (zero lash).  checked the wheel ..... it reads 11 degrees ...i think to myself "there is no way i got that right on the first try"
i have a slotted sprocket , i just set the cam at the stock mark, put the sprocket on and tightened it, BAM first try
i checked it 3 times to make sure ...guess i just got lucky.  or i've had this motor apart so many times my subconscious just knew where the sprocket needed to be  :-X
either way it's a done deal , ported head is on , cam is timed, valves are set.   now i'm got back out and put the carbs back on
check out my high class dial indicator holder,    ;D ;D
i cant believe i got it on the first try       "oh he's a little impressed with myself , don't mind him"
Offline scondon
  • Mmmm......tasty bugs
« Reply #82 on: January 06, 2009, 08:05:08 PM »
  Nice indicator base, Spikey. Forget those high-falootin' magnetic base contraptions with hand knob tighteners, real men use wrenches ;) ;D ;D
   Do yourself a favor, if you haven't already, and set-up/measure the exhaust valve lift as well. My Megacycle cam was spot on the mark and yours may be too, but it is peace of mind and well worth knowing that the cam is dialed in in case you have tuning troubles down the line.
  Keep them pics comin' :) :) :) :)
« Reply #83 on: January 06, 2009, 08:50:14 PM »
Do your lobe centers match the timing card? Megacycle advertizes 105 degree LC's for that cam now, actually all the data is different.
« Reply #84 on: January 06, 2009, 08:51:48 PM »
uuuuuuuuuuuuuuuh  what?
« Reply #85 on: January 06, 2009, 08:56:14 PM »
CAM VALVE DURATION LOBE INTAKE OPEN/CLOSE RUNNING
NUMBER LIFT AT .040" CENTERS DESCRIPTION AND APPLICATION EXHAUST OPEN/CLOSE CLEARANCE
126-00 .296" .240° 105° OK with stock piston and springs. 15 btc/45 abc .004"
.280" 240° 105° Improved mid-range and top-end. 45 bbc/15 atc .005
i tried to cut and paste but it's all broken up , but you can get the idea
this is odd, even the running clearance is different
« Reply #86 on: January 06, 2009, 08:59:48 PM »
NUMBER   LIFT       AT .040"    CENTERS              EXHAUST OPEN/CLOSE   CLEARANCE
126-00   .296"         .240°         105° .                   15 btc/45 abc            .004"
             .280"          240°          105°                     45 bbc/15 atc           .005
the major difference i see in the numbers is the open/close are no longer staggered by 1 degree  (if you look at my timing card )
« Last Edit: January 06, 2009, 09:04:25 PM by spikeybike »
« Reply #87 on: January 06, 2009, 09:03:13 PM »
Maybe just a change in profile from your cam I suppose. By your card the date says 2000, but also says revised timing??
« Reply #88 on: January 06, 2009, 09:05:37 PM »
thats most likely it , i bought it in 01 or 02 i think
edit:  i had to replace the cam in 05 (there was a little mishap with me putting my cam chain guide in backwards :-[ )
and the card they sent the second time is the one you see
« Last Edit: January 06, 2009, 09:10:16 PM by spikeybike »
« Reply #89 on: January 06, 2009, 09:13:55 PM »
I'm with scondon, check the exhaust numbers before you button it up.
« Reply #90 on: January 08, 2009, 07:59:21 AM »
intake is 11  exhaust is 53 ?      not sure if there is some human error in there , but if there isn't i suppose there isn't much i can do about it .
i didn't have time to check it again, i'll go over it again when i get home tonight ,,
along with some other little things i wanna do
Offline scondon
« Reply #91 on: January 08, 2009, 08:16:45 AM »
 Looks like you are right there Spikey. You can either fudge the cam 1/2 degree or leave it as is(in my opinion). Pretty damn good for a "drop in" with a slotted cam sprocket :) :)
    My Megacycle cam was spot on intake and one degree high on exhaust and it screams ;)
« Reply #92 on: January 08, 2009, 09:50:02 AM »
And so...what's the alternative, or likely best setting. Leave Intake spot on and take what Exhaust gives you? Split the difference? Or experiment, likely with a Dyno and the purpose of the slotted sprocket anyway?
I'll be doing this someday myself.
Offline scondon
« Reply #93 on: January 08, 2009, 10:20:59 AM »
   My experience with cam timing is limited to two bikes with different cams. On one bike(megacycle cam) I went by just the open/close #'s and left the exhaust 1 degree off and intake spot on and the engine screams. The second bike(Webcam) had a f##ked timing card so I learned how to measure lobe centers as well and retarded the cam 2 degrees from spec and the engine screamed. Neither bike suffered from bad idle which may be associated with a poorly timed cam.
   In Spikey's case I believe it would really be splitting very fine hairs to move the cam from where it is, in regards to performance difference. I have yet to get a cam to match the card EXACTLY but I enjoy learning the process so I tend to measure,move, remeasure a lot.
  Heads that have been "decked" will change cam timing and a slotted sprocket, at the very least, allows one to move cam timing back to where it should be.
   I mostly just regurgitate what Mrieck has taught me, along with my limited experience, so I will defer to him and other "pro's" for the tough questions ;) :) :)
« Reply #94 on: January 08, 2009, 10:28:14 AM »
that makes me fell better ,    not sure how different this setting is from what i had before, but the bike ran like a raped ape before,
i'm more anxious about the ported head then i am about timing the cam ......   coooome on spring!!!
« Reply #95 on: January 08, 2009, 01:20:58 PM »
Just to be clear Spikey, the intake valve opens @ 11 degrees BTDC and the exhaust valve opens @53 degrees BBDC?
For fun it would be good to know the closing numbers for both the intake ABDC as well as the exhaust ATDC, that way you can determine lobe centers, duration, etc.
I still wonder why Megacycle advertizes LC's of 105 on their site but send a timing card showing numbers way higher. Real world fiqures forced them to alter the card, or is it a completely different cam profile from the one advertized?
« Reply #96 on: January 08, 2009, 01:27:17 PM »
Thanks. That's all i need to know for now. When the time comes, I'll raise the question again, maybe Mike will chime in.
« Reply #97 on: January 13, 2009, 07:53:23 AM »
i took that brace off and chopped it up and remounted it behind the forks , much better i think
man i can't wait to see this motor in the sunlight
Offline mkramer1121
« Reply #98 on: January 13, 2009, 08:21:28 AM »
your missing a tappet cover...:P
« Reply #99 on: January 13, 2009, 10:20:01 AM »
your missing a swift kick to the shin
