Author Topic: speedo bounces  (Read 1411 times)
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
speedo bounces
« on: September 21, 2005, 11:20:46 PM »
Hi my speedo bounces at higher speeds 50 and up  and a little bit at speeds lower then that. I also believe  that the speedo  is  5mph faster then what your really going how do you fix / adjust this
thanks for you help in advance Dan
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline oldbiker
  • I HATE RAIN
Re: speedo bounces
« Reply #1 on: September 22, 2005, 02:44:25 AM »
If the needle is bouncing about, it is most likely due to the drive cable being dirty so that the inner twists and un-twists as you ride. Remove it and withdraw the inner. Make sure that both are quite clean and lubricate with light oil, not grease. Re-assemble and replace. Your speedo should be OK now.
