Author Topic: I cannot seem to get my engine apart  (Read 1548 times)
Peter2
« on: August 25, 2007, 11:14:41 AM »
Good afternoon all,
I am trying to get the Jugs' case off the crank case.  The damn thing is stuck.  There doesn't seem to be anything holding it on.  I have rapped on it with a rubber mallet, sprayed gasket remover all along the seem hoping to penetrate, and have tried prying with a screw driver.  The thing won't budge.  pistons move freely, but that is about all I have going for me right now.
Any suggestions?
Peter2
Re: I cannot seem to get my engine apart
« Reply #1 on: August 25, 2007, 11:15:08 AM »
by the way, it is a 74 cb 550
Offline kghost
« Reply #2 on: August 25, 2007, 11:29:55 AM »
Its always a bolt or a screw you've missed.
Stranger in a strange land
Peter2
« Reply #3 on: August 25, 2007, 12:12:47 PM »
Yeah, I experienced that removing the head, but there doesn't seem to be anything left...
Offline Ottawa_550F
« Reply #4 on: August 25, 2007, 01:27:48 PM »
I think there is one bolt deep inside the oil pan area, did you get that one?
Online bryanj
« Reply #5 on: August 26, 2007, 02:06:05 AM »
On the 500/550 there is a "notch" at either end to fit a small pry bar (read screwdriver) into that is nowhere near any thing inportant
Offline neil young
  • striving to be an
« Reply #6 on: August 26, 2007, 03:02:34 AM »
there is a thread posted on this subject recently.hondaman had a good suggestion.i just cant remember what he said to spray on the engine.apparently it worked for the person who was in the same boat your in.
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
Offline neil young
  • striving to be an
« Reply #7 on: August 26, 2007, 03:17:15 AM »
for some reason i cannot copy and paste the thread.so in a nut shell.hondaman says to spray liquid wrench on the gaskets let sit over night.apply again then take an olfa knife (exacto blade)and start sliceing into the gasket.in the search option i typed in engine apart.the thread title was engine disassembly problems (page two i believe)good luck.
1972 CB500 k1
1974 CB550
1977 cb 550
