Author Topic: Offset rear sprockets  (Read 628 times)
Offline Burnboy
« on: November 01, 2008, 05:35:39 PM »
Does anyone make an offset sprocket kit for running dual chains? Or can I just use 2 standard offset sprockets?
1975 CB750
1973 CB350F
Offline junkyardjon
Re: Offset rear sprockets
« Reply #1 on: November 01, 2008, 06:03:20 PM »
cycle exchange sells a duel chain kit
Offline Burnboy
« Reply #2 on: November 01, 2008, 06:31:42 PM »
but im looking for an offset dual chain so i can fit a larger rear tire
1975 CB750
1973 CB350F
« Reply #3 on: November 01, 2008, 06:41:19 PM »
Why do you want to run dual chains? I guess it's for looks, because a modern 530 chain will handle much more power than our bikes are capable of, even with heavy engine mods.
An offset dual chain setup might cause some clearance problems on the other side, (frame/sprocket cover/rear shocks etc, I presume you won't be running a chain guard) and might also require an "outrigger bearing". Cheers, Terry. ;D
