Author Topic: Dropping Oil Pan  (Read 1361 times)
m goodwin
Dropping Oil Pan
« on: September 22, 2005, 08:08:15 AM »
Guys I'm removing the oil pan to check for sludge ect. and having problem with the bolt directly behind the drain plug.  It's set too close to the pan to get a socket on it and a box end wrench doesn't provide enough room to torque it.  Does this require a special tool? Any help appreciated.
My first of many questions I'm sure.
I'm off to drain and treat the tank.
Offline DammitDan
  • Prodigal Son
  • It lives!
Re: Dropping Oil Pan
« Reply #1 on: September 22, 2005, 09:29:56 AM »
How about a U-joint wrench with a thin-walled socket?
CB750K4
Offline Chris Liston
« Reply #2 on: September 22, 2005, 01:30:31 PM »
thin walled 10mm socket or open /closed end 10mm wrench should do the trick.  Regarding torque, I just snug it up and than 1/4 more.
« Last Edit: September 22, 2005, 01:37:00 PM by Chris Liston »
1976 CB550F Cafe in progress
douglascoolgrey
« Reply #3 on: September 23, 2005, 09:10:43 AM »
1/6 turn, flip wrench, 1/6 turn, flip wrench, repeat, smoke break, repeat, curse, repeat, etc...
« Reply #4 on: September 23, 2005, 11:45:09 AM »
Don't I know it,  the new header on my bike blocks the right side bolts.   What a pain.
