Author Topic: CBR600 EFI for CB750  (Read 9813 times)
KingCustomCycles.com
« on: November 11, 2008, 10:18:23 AM »
I may be incredibly niave here but why couldn't a 2003 and up CBR600 EFI system be adapted to a CB750 intake manifold and run as is?  I work at a large engineering university (Purdue) and could potentially have some really top intellects sort this out.  My area is aviation but we have ME, EE, and AE to name a few.  What do you all think?
Offline Alan F.
Re: CBR600 EFI for CB750
« Reply #1 on: November 11, 2008, 10:28:39 AM »
Sounds like a very sensible approach, I'm all about doing things with off-the-shelf parts.
Offline mmtsquid
« Reply #2 on: November 11, 2008, 10:36:14 AM »
It certainly seems reasonable.
My question is - what could I adapt to work on my 550?
77 CB550K4
Offline crazypj
  • I'm brill, me
« Reply #3 on: November 11, 2008, 10:39:03 AM »
 Guy I work with has fitted two sets of Suzuki TL 1000 throttle bodies to a smallblock V-8.
He's also done Suzuki throttle bodies and injectors on CB750, dont know which model hough (when he gets it sorted out he's going to turbo it again)
Used Megasquirt electronics.
Same guy has also fitted modified inline 4 throttle bodies to VF700
PJ
Offline crazypj
  • I'm brill, me
« Reply #4 on: November 11, 2008, 10:42:15 AM »
  You have to modify center section as most 600's have narrower engines (cam chain on right side, close bore spacing) GSX-R 600 should go in quite easy if you get early model (smaller throttle bodies. an awful lot get crashed- plenty of used spares)
PJ
Offline dusterdude
« Reply #5 on: November 11, 2008, 10:51:42 AM »
yea,the cbr engine is very narrow compared to a 750
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline turboguzzi
« Reply #6 on: November 11, 2008, 11:56:43 AM »
Nice idea, people out there are making EFI kits also for old guzzi's etc. BUT cylinder spacing is only your first problem....
Supersport 600's have 38-40mm throttle bodies meant for 14,000 redlines. Although they are electronically controlled, I dont think they'll "carburate" too well with a relatively slow revving sohc. Way too big and just immagine the step to your, what? 30 mm inlet ports?.
Regretfully, there arent too many modern "small fours" that could have the right size throttle bodies.
If you manage to find EFI throtle bodies that are more in the range of 32-35 then nice...
TG
Offline Alan F.
« Reply #8 on: November 11, 2008, 12:45:36 PM »
A quick search also turned up this:
http://world.honda.com/motorcycle-technology/pgm-fi/
lots of good reading there.
Are any Canadian members familiar with the CBR125R?  I read a while back that it's a fuel injected single making horsepower in the mid twenties...  we might find our 30mm throttle body in there somewhere...I'll keep on it, Honda builds way too many cool bikes we in the US never get to see.
Offline turboguzzi
« Reply #9 on: November 11, 2008, 12:48:40 PM »
Alan, the spacing of these is REALLY bad, SOHCS have biggest distance between cyls. 2 &3, shortest between 1-2, 3-4..... just the opposite.
Let's not forget the electric fuel pump for the EFI. in current bikes it's built inside the gas tanks, with the shape of a SOHC's tank and frame you'd have to build a separate, gravity fed tank just to have the pump immersed in fuel.
TG
Offline ghost
  • what do you mean i can't do that? I just did it didn't i
  • it's all about the last inch baby(even when it's metric)
« Reply #10 on: November 11, 2008, 01:04:38 PM »
i've been wondering the same thing about the 650. maybe someone will figure something out that'll make us all happy
1980 cb650c first bike i owned now the wife's ride.           1982 xv920j virago, bike i learned to ride on rescued it from a 13 year coma (sitting in the shed) now she runs beautifully and rides like a dream.
Offline goon 1492
  • Sucka Repellant
« Reply #11 on: November 11, 2008, 01:19:11 PM »
There is a website I used to study for my old dodge d-100 I had, it had the good ol' slant 6 225 with a three on the tree, I wanted to upgrade it and was learning about the first batch fire 3.8 ltr ignitions and how they could be adpated to a slant six. Not exactly our cup of tea but it can get us in the ball park.
here ya go.
http://www.slantsix.org/articles/dibiase_efi/efi-conversion.htm
Offline Geeto67
  • A grumpy
« Reply #12 on: November 11, 2008, 01:50:17 PM »
here is a stupid question, Why are we married to the idea of individual throttle bodies for each cylinder? As long as you have injectors at each of the individual cylinders what is wrong with having a log style manifold with a centrally mounted throttle body. This opens the spectrum up to more available sensors like Mass Air sensors (most sport bikes are Throttle position sensor) and wide band 02 sensors.
Maintenance Matters Most
ev0lution7
« Reply #13 on: November 11, 2008, 02:45:32 PM »
that guy has a cb750f running EFI
same guy.. this is his webpage
http://www.orleanscycle.com/
Offline turboguzzi
« Reply #14 on: November 11, 2008, 03:41:32 PM »
Cool!
Looks like I'll have to eat a hat or two...  8)
And yet, wouldnt be surprised if the starting problems he mentions about are due to the huge size of the bodies.
Nice project though!
TG
« Reply #15 on: November 11, 2008, 04:04:31 PM »
TG
or use a magna/shadow fuel pump......
Offline crazypj
  • I'm brill, me
« Reply #16 on: November 11, 2008, 08:29:04 PM »
TG
It isnt as much of a problem as you would think.
The reason for relatively small carbs is to have airflow sufficently high to atomise fuel then keep it in suspension in airstream. If carb is too big, airflow stalls and you get fuel drop out,  missfire, etc.
When your spraying fuel directly at intake valve (at 43 PSI) its going to stay atomised long enough to burn.
 with 52mm throttle body on a 250cc cylinder,(GSX-R1000) it can sttill be a problem, that's why there are two throttle plates for each throttle body, one is controlled by ECU, depending on input from MAF, TPS, APS, etc
PJ
Offline XN
« Reply #17 on: November 11, 2008, 08:54:04 PM »
If you plan on using a existing EFI system I would make sure that you could interface the ecm via a dynojet power commander or something along that line to add and subtract fuel as needed.
And as far as the newer bikes bodies being spaced a lot narrower. Maybe a manifold with separate runners to the head could be made. I could maybe help you in this area...
Where there is a will there is a way...
78 Honda CB750K
02 Yamaha V-star 650
02 Honda VTX 1800
