Author Topic: Mount Bolt Specs  (Read 2340 times)
Offline bunghole
Mount Bolt Specs
« on: November 02, 2008, 07:43:10 PM »
Anyone have the specs on the motor mount bolts for a '77 750k?  I'd like to order replacements from McMaster Carr.
Thanks!
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline KB02
Re: Mount Bolt Specs
« Reply #1 on: November 03, 2008, 04:32:52 AM »
I don't think they make bolts long enough; I've checked.
I'll check my 78K tonight (if I can remember to do so for you) and post the measurements. Should be the same from 77 to 78.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline bunghole
« Reply #2 on: November 03, 2008, 09:53:37 AM »
It would be much appreciated.  Any thoughts on where to buy the bolts?
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline SD750F
    • My Business Site
« Reply #3 on: November 03, 2008, 11:57:48 AM »
One thing you can consider is to use standard threaded rod stock. My local hardware store even has it in Stainless. And you can swap out the metric with english. I know the larger of them is almost the same as 1/2 inch. That is as long as you are going to change out all your nuts as well.
Scott
Offline wildcatmahone
  • Poseur
« Reply #4 on: November 03, 2008, 03:43:14 PM »
I think the motor mounts are a M10 x 1.25 thread hard as #$%* to find around I wouldnt recommend using stainless steel for the motor mounts remember it's a grade 2 or 3 steel. OEM Honda bolts were at least a grade 6.
Check out:
http://www.metricspecialties.com/
Offline KB02
« Reply #5 on: November 03, 2008, 04:04:34 PM »
Okay the two front mounting bolts are 1 15/16" long on the timing side, and 3 1/8" long on the stator side.
The front bottom bolt is 10mm by 12 1/4" long (310mm roughly).
The rear bottom bolt (also holds the foot pegs) is 12mm by 13 3/4" long (350mm roughly).
The top rear bolt is 10mm by 11 1/16" long (280mm roughly).
Hope this helps.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline bunghole
« Reply #6 on: November 03, 2008, 04:09:26 PM »
Hope this helps.
KB02...You are a scholar and a gentleman!
I don't think MC Carr has any that long.  I will post a source once I find one!
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline lordmoonpie
    • Moonpie
« Reply #7 on: March 28, 2009, 02:55:02 AM »
You can always get top class mounting bolts from Phil Denton - ex Honda engineer and dealer now runs his own very very superb machine shop producing bolts and lots of other nice things in polished high grade stainless....check him out at www.phildentonengineering.com  ;D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
