Author Topic: Replacement Choke Cable  (Read 1131 times)
Offline bikerboycb650
  • And YOU must be the Monopoly guy!
« on: November 05, 2008, 06:56:34 AM »
Hey guys,
  My 81 Cb650 choke cable is broken, do I HAVE to get an 650 cable or will a 750 work? And would the year matter? It seems like a simple cable. Thanks!
Offline Soos
Re: Replacement Choke Cable
« Reply #1 on: November 05, 2008, 10:10:35 AM »
Choke?
I've rigged other setups to replace the buggered choke cable. I used a friction shift unit off a old 10 speed bike.
It worked, but I had to engineer a widget for the choke lever on the carbs as well.
You can make anything work with enough desperation and lack of $$.
need the mother of invention...
Other than rigging something something up, not too sure.
I have not had experience with the DOHC750/900/1100's, but they may have had a similar choke setup.
Do any SOHC 750 carbs racks have a choke cable? Mabey the later '77/'78 motors with the pumper carbs?
The only examples of SOHC 750 carbs I have seen are mid 70's and they all had a choke lever on the side of the carbs, so no cable at all.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
