Author Topic: The Ever-Popular CB650 bad charging 'issue', formerly hot start 'issue'  (Read 77474 times)
Re: The Ever-Popular CB650 hot-start 'issue'
« Reply #50 on: February 25, 2009, 11:32:51 AM »
Each component in an electrical system "sees" the world through it's connections.  It only knows what it is given and with that, it manipulates it output terminals based on that info.
Therefore, if you suspect the R/R isn't doing its' job, view the world through it's "eyes" monitoring what occurs on its terminals.
We'll work "backwards" through the charging system from battery to the alternator, then back to the battery from the alternator.
First, any wiring or connectors between battery and rectifier R/W and Green connection points, should be checked for good, clean, low resistance connections.  Intermittent, or terminals that are making incidental contact can wreak havoc in a vibration environment.
The rectifier:
The R/R is divided into two distinct sections, as indicated in it's abbreviation.  There is a portion that rectifies the AC coming from the Alternator, turning it into DC power that the battery can use.  The  AC wire inputs are the yellow ones. The outputs are The Green and R/W wires.  Internally, you can check the diode health using a meter with a diode test function. ( --|<|-- )  There are six diodes inside that can fail in a few ways, open (no conduction), shorted conduction regardless of probe polarity, and "mutated", where its response to input conditions is so elaborate as to be unpredictable.   Fortunately, the latter is not so common.  There are 14 test that can be made to the rectifier section.
The first two are an overall test using the Green and R/W wires.  With the R/R disconnected from the bike, place your meter probes on those wires, for reading A _____, and then switch probe contacts and do the test again B _____.
Since the job of the rectifier is to turn alternating current to DC current, the Rectifier should only show conduction or a low meter reading with the probes oriented in one direction only.  The other meter polarity should show a very high resistance if the rectifier is good.
To test each individual diode in the rectifier, requires meter placement on one of the yellow leads and the other on a green or R/W, then switching meter polarity, to repeat the test.  This action will give you 12 more meter readings to write down and relay to whoever is helping diagnose your charging system health.  However, for your own satisfaction, if each diode conduct in one direction only, the Rectifier should be doing it's job.  While it is possible for devices like diodes to change their properties at different temperatures, it is pretty rare.  But, if you want to be thorough, chuck the device in an oven, set for 70 degrees C wait a few minutes and repeat all the above tests.
The wires between the rectifier and the Stator, including any connection terminals should be checked for good, clean, low resistance connections.  Intermittent, or terminals that are making incidental contact can wreak havoc in a vibration environment.
The stator:
The stator is where the yellow wires com from.  There are three coils commonly connected at one end of each coil, so each coil presents one end of its coil to the outside world for power delivery.  It's fairly large wire and few coils winds means that each coil has very low resistance.  This is a good thing for power delivery, but measuring such low resistance requires sensitive equipment and diligent test technique.  Further, you actually test two coil windings at a time, since those are the only electrical access points that are available without destructive disassembly.  Fortunately, the Stator is pretty rugged in normal use.  If you can read less than an ohm between any two yellow leads, and very high resistance between any yellow lead and the frame housing in which it resides, it's probably OK.  Again, if you really think the stator characteristics change with temperature, chuck it in the oven and repeat the tests at a higher temperature.
The Rotor:
The 650 combines the field coil and magnetic metal into one component called the rotor.  It is an electromagnet.  The rotating magnet is what impresses a voltage generation in the Stator.  The speed of the rotation and the strength of the magnet determines the stator power availability. The strength of the magnet is controlled by a voltage delivered to it.  The higher the voltage, the stronger the magnet.  The individual winding wire has an insulation coating to separate it from all the rest of the winding layers as well as the metal rotor frame.  Centrifugal forces are considerable in this rotating assembly, and there forces, along with heat softening the materials can cause the wire insulation to fail its primary purpose.
The winding resistance then changes along with the strength of the alternator output.  Since I don't have a known good rotor, and no Honda specification for this winding resistance is available to me, I only have anecdotal reports of "standard" resistance, which has varied from about 5 to 7 ohms.
So, the first test on the rotor would be to measure it's resistance at the rings where the brushes make contact.  Then measure again where the terminals meet the regulator to verify and specify what resistance the windings have.
Again this can be checked with heat applied and even better, you can check the stability of the rotor winding resistance while the engine is hot and running with some precautions and careful wire connection scrutiny. (More about this later)
It is certainly true that the lower the rotor resistance reading, the more current and power it will draw from the battery.  If the there are windings shorted within the rotor, it is also making a poorer electromagnet and reducing the power output capability of the alternator.
But, first lets move toward the "Regulator" after we have verified that the connections between the rotor and regulator are checked for good, clean, low resistance connections.  Intermittent, or terminals that are making incidental contact can wreak havoc in a vibration environment.
The "Regulator":
The regulator maintains system voltage indirectly, by means of battery charge state.  There is a black lead connected to the regulator which serves multiple functions.  One function is to supply the regulator with the power it need to operate. another function is to provide the power that regulator distributes to the alternator rotor.  And yet another important function is as a monitor of the battery charge state.  The regulator make s decision on how much voltage the give the alternator rotor based on the voltage it "sees" on that Black wire terminal.  If terminal indicates that the battery is undercharged, the regulator passes more voltage from that black wire on to the alternator field coil, strengthening the electromagnet and the stator output capability. (assuming rotor and interconnections are operating properly)  Conversely, if the regulators black wire terminal indicates the battery is overcharged, the regulator "pinches off" voltage going to the rotor, reducing the mag field and alternator output capability.
Now you should see the importance of the black wire reporting true conditions of the battery to the regulator.  Which means all the wires between the regulator and the Battery, including any connection terminals, and SWITCHES, should be checked for good, clean, low resistance connections.  Intermittent, or terminals and contacts that are making incidental contact can wreak havoc in a vibration environment.
The "hot-start" problem does not separate two other factors in the scenario.  Time and operating vibration.  You can't make it hot without time to reach the temperature, and since the engine is heating from within, it vibrates while getting to the "hot" point of the problem.
The starter can still turn slowly, if at all, when the battery is low.
Which is why I ask for a battery voltage when the problem is first identified.  If the battery is strong and the starter turns over slowly, it guides troubleshooting into another direction, away from the charging system.  If time, heat, and/or vibration is diminishing charging capability, then the charging systems needs further scrutiny.
ASSUMING, that the battery voltage is actually low during hot start, there are more test that can be performed to isolate the actual cause.  If all the cold testing has not revealed a smoking gun.  Then you have to test when the bike is still in the failure condition. (battery voltage?)
Has the black wire voltage delivery been diminished/corrupted? (voltage reading under failure conditions)
Has the rotor resistance changed?
With the engine hot, and the regulator disconnected at the black wire terminal AND the two connections to the field coil, what is the rotor resistance at the connection wires when the engine is hot, running and revved up?  (may have to bump start the bike to make this test.  And since the alternator can't provide output during this test, take out the headlight fuse to reduce the drain on the battery).
Which makes me think of another test.  When you have a "Hot Start" issue, does removing the headlight fuse improve starting? or no change?
Now to your questions:   :)
I do have a question.  As the R/R was reading 14.9-15v, it indicates the regulator isn't doing its job.
OR, the regulator is being lied to about the true state of the battery. When the battery was at 14.9-15v, what was the voltage between the Black and Green terminals of the regulator?
If the stator has started to 'go' as it were, and is "taking the R/R with it",  will it kill a new RR if I replace this one?
Assuming you actually meant to say rotor, instead of stator, there is some risk to the R/R.  Lower rotor resistance demands more current/power delivered through the regulator.  It is safe to say that unless the regulator has some built in over-current protection scheme inside that inaccessible container, exceeding it's current capacity will damage it.  I don't know specifically its internal design or the specific components used to handle the current flow.
But, consider this.  If your slip rings are "floating" and not make strong contact, or the interconnect wires are intermittent, while the engine is operating, the rotor resistance looks higher from the regulator's perspective and it then provides >less< current in this case, and the lower current diminishes alternator output capability, which would allow the battery to reduce charge state regardless of what the regulator is telling the alternator to do.  It would be like shouting at a deaf child, from the regulator's perspective.
Should I keep this one until I can be very sure of the stator's status?  How do I test the stator *directly* instead of through the wiring?
I think I answered the rotor/stator testing above.
There are two schools of troubleshoot/ repair of things electrical.
One is to identify the bad component and replace it.
Another is to keep replacing parts until it works again.
It's a time/effort vs. money thing, if you don't bargain in the quest for knowledge.
Which do you have more of?  What's is it that you wish to accumulate the most of?
Anyway, at this time, I don't think you've proven your regulator is "bad" yet.
PS.  I don't have time to proofread this right now.  So, I may have to edit this after I get back from errands.
Offline Frankenkit
  • Industrial Strength
« Reply #51 on: February 25, 2009, 03:22:08 PM »
Alright, TT, I'll start on testing that as soon as I get a chance.  I wanted to relate that today I'm cleaning connections prior to friday (or Saturday, depending on how things go) as a 'major testing' day.  I did have what I would consider an interesting finding today.  Having been told my issue may more accurately revolve around the ignition switch and those connections, (and knowing there were approx. a quarter million connections in the filthy headlight bucket that needed to be addressed) I started there.
Having just separated the ignition switch from the male plug that goes into it, the red lead (+ I'm assuming) was covered in all colors of green/white/ and pink, sort of copper looking oxidation and gunk.  I'm setting about cleaning it up now, but suspect that may have been a large amount of my problem.
I replaced the fuses (15a, not 10. my mistake) and, pending finishing the ignition switch's major cleanup, will start reassembly of the headlight bucket.
You had asked about the 'hot start' issue, and it will continue to crank very slowly at 12v,  slowing progressively to 11.6.  Around 11.4 it will no longer start while the bike is warm, but will (eventually) crank over when the bike has cooled off, and idle like crap because (I'm guessing) the battery is low and spark is weaker.
I'll test this as soon as I have everything reassembled and can take the bike for enough of a ride to kill it.
Until then, I'll test the RR's diodes and get back to you with those 14 results.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
« Reply #52 on: February 25, 2009, 04:30:41 PM »
From : http://en.wikipedia.org/wiki/Lead-acid_battery
These are general voltage ranges for six-cell lead-acid batteries:
    * Open-circuit (quiescent) at full charge: 12.6 V to 12.8 V (2.10-2.13V per cell)
    * Open-circuit at full discharge: 11.8 V to 12.0 V
    * Loaded at full discharge: 10.5 V.
It really isn't surprising that the battery won't start the bike when "hot", as there is little energy left that can be drawn from the starter motor when the voltage is as low as you report.  Sure seems you have a depleting battery issue with heat being irrelevant to the problem.  A recently depleted battery will recover somewhat after sitting for a short while.  (It's a chemistry thing.)
Could well be that terminal corrosion or even key switch internal contact wear is causal to the deteriorating battery while running the bike.  These components are in the path that feed the regulator its power and battery voltage info.  While ultimately it is going to be some sort of mechanical repair that puts things aright, I prefer to probe electrically and let the readings tell me where the mechanical connection fault exists.  If you prefer to mechanically overhaul the entire electrical circuit path, in the hopes that you will eventually stumble upon the problem visually, that is still an effective repair technique, if perhaps a bit inefficient.  ;D  Certainly working on the bike can be an enjoyable endeavor/pastime/hobby all by itself.  I kinda got the impression you would rather ride at this point, so I was going for expedience in the corrective approach.  You CAN probably fix it without ever using the dreaded meter.  But, you may have to touch every single bit of the electrical path to do it, depending on how "lucky" you are.  I find the odds of doing it this way means that the last bit in circuit I touch cures it, having replaced or overhauled everything else first.  That's why I learned to cozy up to a meter early in my "fix-it" career.  Besides, I like both cerebral exercises as well as hand coordination/prowess skills.  Kinda fun if you can look at a page of data points and go "Oh, this tells me >that< part of the circuit is wrong and needs attention".  Then correct that, and everything works as predicted.  Also gives you confidence in the rest of the device circuitry/device, too.
Offline Frankenkit
« Reply #53 on: February 25, 2009, 07:52:54 PM »
Some of this work is going to be on hold.  My latest carb repair has apparently failed. I had some o-rings that were a bit chewed up, so I tried to use a touch of gasket-maker to snug them up where they were insufficient.  Unfortunately, that didn't work as well as I'd hoped, so my carbs are leaking pretty badly.  I suspect that my repair for the air cut-offs are responding the same way as I used the same material...  :-\ ::)  I can't say it's terribly unexpected, I'd just hoped the stuff would be more gas-resistant than it turned out to be.  The idle jets had already been acting clogged, so I have my answer.
I'll take this setback as reason to go ahead and spend my tax refund on OEM carb kits and air cutoff diaphragms, as I hadn't been able to afford them previously.  My jerry-rigged fixes have done okay from time to time, but this I need to do right.
I did, however, test my RR diodes, and though I left the notebook outside ::) the results were, I believe, favorable.  Electricity only flowed one way, resistance at 0.85 Ohms from RW to Green.  OL the other way.
Green to the three yellows varied from 0.780-0.77 ohms, and OL the other direction.  RW was lower from 0.76-0.54 Ohms, OL the other direction.
The diode hanging off the wiring harness under the gas tank was 0.86 and OL the reverse polarity.
I know I need to do a drain test and will do that Friday morning while I'm out taking the carbs off.  After reassembling the headlight bucket and all the plugs/wires/doodads inside, I did have to turn the key 'on' to make sure I had it 'right'.  Everything lit up, and actually a bit brighter than usual.  Starter cranked a LOT faster, though I didn't want to start it up, considering the gas leak through the carbs, etc.
« Last Edit: February 25, 2009, 08:01:01 PM by Kit »
1973 CL350- Lola?
Stuff for sale
Offline Hush
« Reply #54 on: February 25, 2009, 10:06:26 PM »
Wanna come an clean my electrics up? ;D
After saying I had no charging issues it appears I suffer from the CB650 lurgie too. :(
Bike starts when battery charged but weakens as I ride it!
Offline Frankenkit
« Reply #55 on: February 26, 2009, 07:29:21 AM »
See?! See?! and Hush, I trust you wring out the throttle like I do when riding, or more, and it still does it to you!  At least you can go through the many steps I have and start figuring things out... I dropped SO much money on that bike last night I can't believe it. Honda charges $40 per carb kit and $20 for each air cut-off diaphragm.  :o  the only way I could justify it was that I have another few weeks and paychecks between now and tuition payments. Well, that and I went all in and got a $15 new horn cuz mine's like a lovesick moose, and a new plastic connection holder for inside the headlight bucket. Mine is just holding together with glue... and the glue is undoubtedly the strongest part of it. ::)
1973 CL350- Lola?
Stuff for sale
Offline Hush
« Reply #56 on: February 26, 2009, 07:41:43 AM »
I dunno Kit, maybe I should just spend a hundred bucks and get a battery maintainer, you know the permanent trickle charger that you plug the bike into when you aren't riding it?
Not sure how bad my power loss is, I'm off on leave for the next 3 weeks so will try riding the bike all day at some stage and see if it dies totally over time.
As for ringing it out ;D the industrial/agricultural nature of the gearbox means you need to have the throttle full open to get any decent speed anyway on the highway.
Offline Gordon
  • 750K1, 550K2
« Reply #57 on: February 26, 2009, 07:46:47 AM »
You don't need to spend $100 to do that.  You can get a Battery Tender jr. for $30.
Offline Hush
« Reply #58 on: February 26, 2009, 07:52:36 AM »
That would be in Denver Colorado I presume Gordon? ;D
Out here in the "colonies" we pay like triple for anything like that, we can only dream of walking into a store and buying half the stuff you guys in the US talk about for our bikes.
You gotta remember we only have 4 million people in the whole of NZ, that's not a small city anywhere else. :D
Offline Frankenkit
« Reply #59 on: February 26, 2009, 07:54:19 AM »
Batt. tenders work good but I have this dream of riding to work sometime... can't plug in at wk...
1973 CL350- Lola?
Stuff for sale
Offline Hush
« Reply #60 on: February 26, 2009, 07:56:13 AM »
Riding to work!
Jezz girl hush your mouth I say hush your mouth, for that you would need total reliability, what on earth are you thinking? ;D
Offline Gordon
  • 750K1, 550K2
« Reply #61 on: February 26, 2009, 08:02:11 AM »
Nope, that's the price from Z1 Enterprises in New York.  You have the same parts/merchandise available to you that anybody else in the world with a postal service and access to the internet has.  I know shipping isn't free, but I seriously doubt it would cost $70 either.
Offline Frankenkit
« Reply #62 on: February 26, 2009, 08:15:56 AM »
Riding to work!
*shame* I know... what am I thinking? :D  I must be delusional!
1973 CL350- Lola?
Stuff for sale
Offline Frankenkit
« Reply #63 on: March 26, 2009, 11:56:21 AM »
*lights the TwoTired beacon*
I have new data.
Went for a ride today *YAY!* over a few miles after the bike got warmed up.  Bike was sitting on a trickle charger all night so well-charged.
After the ride, it repeated its non-restarting routine, but it was different this time.  This time instead of cranking super-slow, it was only moderately slow, all the lights were bright etc, and the multimeter read 12.36v.
When cranking, it'd crank once or twice (I didn't hold the button terribly long b/c it wasn't going anywhere and when the bike is hot and WANTS to start it'll fire the first or second try) and I'd hear a loud CLICK somewhere beneath me.
I'm wondering if that's the starter solenoid or the starter clutch?  The CLICK was repeatable, most of the time.
1973 CL350- Lola?
Stuff for sale
« Reply #64 on: March 26, 2009, 06:20:25 PM »
When the starter solenoid is energized it drives a metal slug onto two large contacts inside.  Definitely makes a click.
If the starter clutch is like the one on the 550, it's a roller ramp type one way clutch.  I think it is a sprag type, if memory serves.  It better not be clicking, or you'll have to get inside the crankcase to find out why.
Sometimes the cable between solenoid and starter motor loses some insulation, allowing it near or touching the engine case.  If the cable core is grazing the case a little bit, it will snap when power as applied.  Makes a spark, too, if the eye can view it.  Inspection time...
Also, 12.36 V isn't fully charged, if this measurement is for an open circuit battery.  Was this measurement taken with the lights on?
The charging system ought to maintain the battery at about 13.8 during run condition above idle.  Open circuit, it should drop to about 12.6-ish after two hours, falling rapidly at first, then sneaking up on the full quiescent open circuit voltage.
What voltage does the battery drop to while the starter is engaged?  If it is going below 10.5V, we have a lead to investigate.  Either a weakened battery or excessive current draw beyond what a good battery can provide.
Below from Wiki: http://en.wikipedia.org/wiki/Lead-acid_battery
    * Continuous-preservation (float) charging: 13.4 V for gelled electrolyte; 13.5 V for AGM (absorbed glass mat) and 13.8 V for flooded cells
   1. All voltages are at 20 °C, and must be adjusted -0.022V/°C for temperature changes.
   2. Float voltage recommendations vary, according to the manufacturer's recommendation.
   3. Precise (±0.05 V) float voltage is critical to longevity; too low (sulfation) is almost as bad as too high (corrosion and electrolyte loss)
    * Typical (daily) charging: 14.2 V to 14.5 V (depending on manufacturer's recommendation)
    * Equalization charging (for flooded lead acids): 15 V for no more than 2 hours. Battery temperature must be monitored.
    * Gassing threshold: 14.4 V
    * After full charge the terminal voltage will drop quickly to 13.2 V and then slowly to 12.6 V.
Offline Frankenkit
« Reply #65 on: March 26, 2009, 06:33:17 PM »
Ok, I have a question on pickup coils. Maybe.
I went through my bike testing electrical connections, this, that, and the other thing, cleaned everything, and still, though my bike certainly charges better (and I don't think charging is necessarily the issue anymore) it's just not re-starting up to par when it's been ridden any amount of time.
This is a big issue for me, just in case I snuff it at an intersection I can't bump-start it on, etc.
I went for a ride over a few miles today, got home and tried to re-start while the bike was still hot (operating temp).  I'm limiting my button-pressing to about 5sec because if it's *going* to start, it does so in the first couple of pulses from the starter.  With the battery reading 12.36 volts,  the starter turns relatively slowly, but more importantly I was hearing a fairly loud 'click' like the Suzuki Savage's starter solenoid.
this site suggests
Quote from: Triumphrat
Pickup Coil failure symptoms:
-- No spark at all
-- Spark quits with engine hot, returns when engine cool.
-- Note: Pickup coil failure is total. There is no random misfire spark loss.
Repair:
-- Replace pickup coil
Failure mode:
-- Thermal intermittant with long (15-30 minute) period.
Preventative Maintenance:
-- None. Get a spare.
Testing:
-- Ohms checks hot and cold.
This makes me wonder, because generally, when my bike quits for awhile, it takes 15-30 minutes, generally, to be able to start again.
This is the only situation listed on that site that seems to apply.
TT, that reading was taken post-ride, with the lights etc shut off.
« Last Edit: March 26, 2009, 06:36:22 PM by Kit »
1973 CL350- Lola?
Stuff for sale
Offline Hush
« Reply #66 on: March 26, 2009, 07:20:48 PM »
As TT said, that "click" is the solenoid, if it was working 100% correctly you would not hear it at all, you will only hear that click if it "bounces".....doesn't make fantastic contact across the posts.
The one sure fire way of testing if it is your solenoid or starter motor or even the start button is to eliminate most by shorting the two posts with a large clean screw driver.
If it now fires then you can discount battery/starter/button and return to a dirty/failing solenoid.
Just a brilliant thought but why don't you borrow the solenoid off Mickeys' bike and see if it still does that, her 650 won't need a solenoid for a while yet and if it cures your basic problems you can scoop one up from wreckers before she beats you up. ;D
Offline MickeyX
« Reply #67 on: March 26, 2009, 07:30:55 PM »
I was wondering how long it would take before someone suggested that the other bike gets scavenged...
Offline Hush
« Reply #68 on: March 26, 2009, 07:32:16 PM »
Funnily enough (well more tragic than funny) but my bike is exhibiting exactly your symptoms.
Do you think my bike is coping out in sympathy with a sista?
Seriously mine is doing the "I hate starting when I'm hot" bit, very annoying as I know I'm clever enough to figure this one out. >:(
Maybe I'll fit a button between the solenoid posts that is accessible from outside the side covers and see if I can boot her up from that after a long ride.
The bike does recover and starts fine later....or the next day.....and bump starting is no big deal even with all her finery on....but I'm 5'8" and these are quite big pieces of machinery to be crash starting. :D
Offline Hush
« Reply #69 on: March 26, 2009, 07:34:04 PM »
Scavenged, heck no Mickey.....raped and pillaged more like! ;D
Hey if it cures Kits' bike then you are a long way down the road to helping with your 650 once she is mobile.
Offline MickeyX
« Reply #70 on: March 26, 2009, 07:38:06 PM »
Hahaha. It's ok. Since we are co-owners of the the other bike, she can grab what she wants or needs off of it. If it helps figure out what's going on, I'm all for it.
Offline Frankenkit
« Reply #71 on: March 26, 2009, 07:38:16 PM »
Don't I know it!  Last time I took her for a ride and she did that crap to me, I said "Fine! Be that way!" and let her sit outside, alone, and think it over.  Eventually she decided she didn't like the rain much and wanted to sit in the garage, thanks.
It's your turn for a working answer.  I gave you the 'clean yer ignition switch' answer, after you told me how to clean the starter solenoid...
« Last Edit: March 26, 2009, 07:40:52 PM by Kit »
1973 CL350- Lola?
Stuff for sale
Offline Frankenkit
« Reply #72 on: March 26, 2009, 07:42:12 PM »
TT is going to get sick of both of us! :P
1973 CL350- Lola?
Stuff for sale
Offline Hush
« Reply #73 on: March 26, 2009, 07:49:30 PM »
No way, TT has the patience of a Saint :D.
You have the perfect chance to test our theory and it wn't cost you $$, just borrow the other 650's solenoid and put it in your bike, if that cures it I'm off to my wreckers to get a replacement.....if not it cost us nothing. ;D
Offline Frankenkit
« Reply #74 on: March 26, 2009, 07:50:30 PM »
Here's hopin' the other one's not shot, too!
1973 CL350- Lola?
Stuff for sale
