We went for a nice ride for a few hours, stopped 1/2 way to chat and rest. She started up just fine again, cooled enough just to need a bit of choke for a few minutes and away we went. Got home, re-checked a few things and noticed something weird. Well, at least to me it's weird...
The rotor checked out okay (when still hot) across the rings, the yellow wires checked out okay, but the wiring from the brushes was a little suspect. I'm wondering what they
should show for resistance? The one was at 1.3ohms, one at .8 ohms, measuring each separately from one end to the other, tip of brush to end of wire. (I've been wondering if one or both get too hot or are a bit crispy after all this time) I will recheck them now that everything is cooled way down to see if it changes.
Edit: well, I went back out there to check the brushes to the end of the wiring to see if the resistance had changed. So, upon experimenting, I learned something. I'm just not sure what I learned.
![Cheesy :D](http://forums.sohc4.net/Smileys/default/cheesy.gif)
So... I checked resistance on each and they had changed drastically.
But! upon pushing the brush in just a hair on one of them, the resistance dropped to .6 ohms. ?? Then I did the same to the other one and it dropped to .6 ohms. Jut barely touching the tip of the brush though, they varied from 1.4 -3.2 ohms.
What I'm wondering is... do the brushes sit up against the rotor and depending on how long they are (how new they are), they get pushed into the housing against the springs and it gives a steady resistance? Maybe if one or both get worn down just a smidge too much, they don't get pushed back in from the rotor and they don't conduct as well? Or the other way around, maybe the spring gets worn won't let them contact the rotor enough? As you can see, I know nothing about the brushes to rotor contact or if they should touch at all... I'm just throwing some stuff out there. It just struck me that the R would change so much and fluctuate like that depending on IF the brush was pushed into it's housing. Any amount of the brush being pushed in though, no matter how deep or shallow, gave .6 ohms. Any thoughts would be greatly appreciated.
So the $64 question is... should we be looking to replace the brushes? Are they at the end of their life?
As for the black and white wires from the brushes, I isolated them without the brushes and they have continuity and measure .3 ohms cold.
