Author Topic: The Ever-Popular CB650 bad charging 'issue', formerly hot start 'issue'  (Read 105155 times)
Offline Hush
Re: The Ever-Popular CB650 bad charging 'issue', formerly hot start 'issue'
« Reply #275 on: September 23, 2009, 09:57:57 AM »
12 volt bikes need a good battery to run well Kit, my partners GSX400 wont even idle if the battery is below a good charge, once charged it fires right up, my 650 is the same.
It is the only shared part except for gas (and the mains) that all cylinders use so it could be that his battery is the problem.
Will be interesting to see if Lee's solution works, I use a Yuasa battery, probably one of the better named lead/acid battery makers for bikes. :)
Offline Frankenkit
  • Industrial Strength
« Reply #276 on: September 23, 2009, 10:12:54 AM »
ooookkkkkkaaaaayyyy, I got schooled. :D
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline BVCB650
  • Too Much Thin Air
« Reply #277 on: September 23, 2009, 10:16:48 AM »
That's why I use a Battery Tender Jr. I keep it plugged in. Easy to see what mode it is in. My bike charges fine, but just in case......
1979 CB650, 25K miles, recently refurbished
Offline leekellerking
« Reply #278 on: September 23, 2009, 10:53:19 AM »
That is why I am going to install the new battery (which it needs regardless) and keep an eye on things with my new $20 VOM.
One of the weird things with the charging system on my Honda, among others, is that it uses an electromagnet, not a permanent magnet, in the alternator.  No power to the electromagnet and the alternator does not work.
I will be checking connectors, etc., too!  I just HOPE it is only the battery.  Let's see how things work tomorrow and the next few days.
Oh, and by the way -- when my last battery went bad it started out as "marginal" according to the test run by AutoZone. This battery read "Bad."  No marginal about it; bad to the bone.  That may have caused the sudden loss of power.
Lee
« Last Edit: September 23, 2009, 10:54:59 AM by leekellerking »
My Nighthawk is put together with wire and zip ties, burns oil, and handles like a pig.  I love it!
Offline BVCB650
  • Too Much Thin Air
« Reply #279 on: September 23, 2009, 11:03:24 AM »
Mine were warm enough to get my attention once. I felt that the way they had them mounted on the rectifier bolt, it was getting heat soak off of the reg-rec so I insulated them with nylon washers. So far so good.
« Reply #280 on: September 25, 2009, 06:30:30 AM »
Well, it wasn't the battery. :(
Lee
Offline BVCB650
  • Too Much Thin Air
« Reply #281 on: September 25, 2009, 06:48:56 AM »
Bummer!
Offline Frankenkit
« Reply #282 on: September 25, 2009, 08:05:46 AM »
Hey, Lee, does it start running badly before it cuts out, or is it a sudden sorta thing?  I'm just wondering because on the 650 forum a guy had problems with his bike cutting out once it got nice and hot and it ended up being a heat soak problem with his pickup coils (the ones under the round right cover on the plate around the crankshaft.  I just woke up so cut me some slack... ;))  The bike would start up again once they cooled, however.  Until then, it'd only run on two if it ran at all.
I'm just throwing out guesses here... :(
1973 CL350- Lola?
Stuff for sale
« Reply #283 on: September 25, 2009, 09:59:29 AM »
Yes, it does start running poorly right before it cuts out, but the whole process is pretty quick (a minute or so?).  When it cools down, the battery is too low to turn the starter.
Also, it doesn't happen until after (1) I ride 28 miles to work, (2) the bike sits all day, and (3) I [attempt to] ride home.
So I am [now] thinking it is not charging.  Question is, why?
I have, within the last year, replaced the rotor and the Regulator/Rectifier.  Short in the stator cable?  Bad connection(s)?
I will try and find out this weekend. (And I probably need to re-read this entire thread).
Lee
Offline BVCB650
  • Too Much Thin Air
« Reply #284 on: September 25, 2009, 10:01:36 AM »
Worn carbon brushes in the stator system? They are supposed to have little wear lines on them. I have one that wears quicker than the other for some reason.
« Reply #285 on: September 25, 2009, 10:30:45 AM »
Time to bring a DMM with you to measure battery voltage when it quits.
« Reply #286 on: September 25, 2009, 10:49:19 AM »
I was thinking the same thing.  I now have read [somewhere] that I was supposed to replace the brushes when I replaced the rotor.
Anybody ever replaced the brushes?  Did you use the hideously expensive Honda parts ($64 a set if you can find them) or aftermarket ($12 a set)?
I was ready to pay retail, but Wild West Honda doesn't have them in stock.
Lee
Offline BVCB650
  • Too Much Thin Air
« Reply #287 on: September 25, 2009, 11:53:58 AM »
Lee
I have one that will need replacing in about 1/4 inch or so. I never replaced the rotor although they say you should.
http://images.google.com/imgres?imgurl=http://www.regulatorrectifier.com/catalog/images/10-113.jpg&imgrefurl=http://www.regulatorrectifier.com/catalog/p1800/Honda-CB650-CB-750-CB900-CB1000C-CB1100-Rotor-Brushes/product_info.html%3FosCsid%3De86f027f95f5b9a28d729e8086220d16&usg=__EUHyn5BnpOk4BOm2SO2qHRqW1K4=&h=243&w=324&sz=64&hl=en&start=1&um=1&tbnid=AJQWJYjiV5HIwM:&tbnh=89&tbnw=118&prev=/images%3Fq%3D1979%2Bhonda%2Bcb650%2Brectifier%26hl%3Den%26rlz%3D1T4DKUS_enUS229US230%26sa%3DN%26um%3D1
Offline Frankenkit
« Reply #288 on: September 25, 2009, 02:16:48 PM »
I got my brushes at partsnmore, I think, and they were pretty cheap there, like $15.
1973 CL350- Lola?
Stuff for sale
Offline Hush
« Reply #289 on: September 25, 2009, 03:43:44 PM »
Damn his problem sure sounds like your original problem eh Kit.
But Lee seems to have replaced all the bits you did.
Seems like a charging issue, like the charging system isn't working at all.
He can get to work (probably on the stored battery power) but can't ride home (cos he's used all teh battery up).
OK Lee do the brushes mate, they are a piece of pie to replace anyway....good luck with this..Hush.
« Last Edit: September 25, 2009, 03:45:54 PM by Hush »
Offline Frankenkit
« Reply #290 on: September 25, 2009, 06:10:08 PM »
no, mine didn't really cut out ever. It just wouldn't start up until after it sat and cooled after awhile.  I still think Lee should test the brush resistance (resistance between the black and white wires) at his RR before touching anything else. TT is right though. We need to know what his battery voltage is when the bike is cutting out, if it's truly dead or if whatever mechanism starts the bike is inhibited by running heat (or acquired heat from a short).
« Last Edit: September 25, 2009, 07:20:44 PM by Kit »
1973 CL350- Lola?
Stuff for sale
Offline Achmed
« Reply #291 on: September 25, 2009, 06:59:53 PM »
Some dead horse and poop pictures are what this thread looks to be needing.
Offline Frankenkit
« Reply #292 on: September 25, 2009, 07:16:26 PM »
I dunno, this doesn't look like an ongoing argument with namecalling and implied insults to me, Achmed.  No one here is talking about the effectiveness of a product nor attempting to disprove said claims with data nor theory.  This is a discussion about the effectiveness of Honda's CB650/CB750C/CB900/CB1100/CX500/CX650 charging systems.
  BUT if you happen to own a bike mentioned above that's not charging or is cutting out, then by all means Achmed, post whatever you'd like.
I think Lee, TT, Hush and I have covered enough new ground here that we've yet to beat dead horses.
« Last Edit: September 25, 2009, 07:22:36 PM by Kit »
1973 CL350- Lola?
Stuff for sale
« Reply #293 on: September 25, 2009, 10:37:57 PM »
Hear! Hear!
Now, back to our regularly scheduled program -- I think I've fixed it!
Apparently, a couple of the yellow stator wires were rubbing agaiinst the frame near the connector to the reg/rec.
I replaced the burnt connectior with a spare (I got from Tony Weeks, BTW -- great guy at www.oregonmotorcycleparts.com) and we appear to be back in business.
I now get 12.5 volts at 2,500 rpm (I was getting less than 12 volts, this afternoon).  That sounds right, doesn't it Kit and Hush?
The sad part is  that if I'd followed Kits advice a few weeks ago and given the charging system a good inspection, I'd have avoided getting stranded.  When will I learn???
[/img]
Offline Frankenkit
« Reply #294 on: September 25, 2009, 10:51:10 PM »
Hey Lee, I'm wondering... I was able to cram that big 6 point connector through the original slot for it, despite having one of Tony's RRs.  It was a bit of a 'different' fit, but it all held together and keeps things tucked in nice 'n neat.  Might help you avoid this in the future.
  12.5v at 2500 sounds about right.  Make sure you test as you go up to 5k, maybe have your wife hold the probes while you crank the throttle. Make sure you max out around 13.9-14.9ish just to be SURE you're makin' juice, but that definitely looks like that would've been the problem.
I think we all have our "I think I did it!" moments only to be followed closely by "Ooohh.  Didn't do it." moments.  My bike still starts slow sometimes despite a full battery so that bears more investigation.  ...and here I thought I had it, too, by monkeying with the start button's wiring.
Glad you found that, though! Lucky that you have the extra connector, too!
1973 CL350- Lola?
Stuff for sale
Offline Hush
« Reply #295 on: September 25, 2009, 10:57:35 PM »
Yuck Lee that looks ugly, guess you found your bogie. :)
Kit, you have Iridium plugs in your 650, what make and number are they?
Iridium plugs are very expensive over here, they even sell second hand ones for like $50 for 4!
My bike was running a bit hairy today and I did the old touch-burn-ouch test to find #4 wasn't firing, replaced plug and all good, 30 mile ride just cos I could  ;D and she's running fine but am seriously considering the advantages of the Iridium plugs.
« Last Edit: September 26, 2009, 02:51:00 AM by Hush »
« Reply #296 on: September 26, 2009, 04:48:32 PM »
I get 13.5 volts at 5,000 rpm.  (If I stand on the right hand side of the bike and hold the leads in my left hand, I can twist the throttle with my right hand.  All that Vietnamese and Chinese food eating finally paid off!)
I thought I read that more than about the mid 13s would boil your battery?  Was I dreaming?  ;D
Ignorant question, Kit -- do I check the brush resistance while the bike is off or while it is running?
Lee
Offline Frankenkit
« Reply #297 on: September 26, 2009, 06:31:29 PM »
In theory it should be the same both ways, Lee, but out of ease I'd just leave the bike off. Disconnect the big 6-spade connector (the one with the three stator spades and the black and white one) and test the black and white ones' resistance.  You sound like you're charging alright though, but this is just out of curiosity and to cover all your bases and make sure your brushes are ok.
1973 CL350- Lola?
Stuff for sale
Offline BVCB650
  • Too Much Thin Air
« Reply #298 on: September 26, 2009, 07:51:30 PM »
Lee
Maybe dreaming. 14-15 is max, but still normal.
Offline Hush
« Reply #299 on: September 27, 2009, 02:34:36 AM »
Yeah I can get 14 to 15 volts out of my charging circuit but my battery tends to lose water frequently so maybe I'm not the one you should go by. ;D
