Author Topic: can I hell get the filterbox back on  (Read 646 times)
Offline tworiversuk
  • cb750k7
« on: November 07, 2008, 02:11:33 AM »
can anyone tell me the position the 4 filter box tubes should be in ,they have a flat spot oposite a small nipple, when I push the top section in place the tubes come out of the box, I can either get them on the carbs or in the filter box but not both together, HELP PLEASE, also under the tank they are 3 spare spade connector wires 2 are for the horn where does the 3rd go, all the coil wires are connected OK
Life's just a box of chocolates
Offline Hush
Re: can I hell get the filterbox back on
« Reply #1 on: November 07, 2008, 11:03:50 AM »
Looks like you have a 750, but maybe this will work for you as it did on my 650.
Get the airbox rubbers on and clamped, then get your head rubbers as close as possible, now comes leap of faith...using nice large soft block of wood and my favourite tool the BFH (Big F*#@ Hammer) tap the carbs forward but only tap on the very end of the carb rack shoulder.
Alternate from side to side and they should slide on, I used some grease on the inside of the rubbers to give them some slideability. ;D
I know this is not the PC way to do this but needs must.
I have heard of guys using 2 large wood clamps placed on shoulders and at front of head, he eased the carbs onto the head by slowly winding in the clamps, great idea but I don't have the clamps. :D
I have since learned that there are arrows on the head ports at the very top moulded into the alloy which should be lined up with the arrows on the carb rubbers...as I said this is on a CB650 79 but hey no one else was replying to you.
« Last Edit: November 07, 2008, 11:06:14 AM by Hush »
Offline kach_me
« Reply #2 on: November 08, 2008, 03:00:08 PM »
I put the tubes on the air box this past summer and had problems getting them to go on the carbs.  Too tight and I wasn't making any progress.  I then got the idea to put some golf balls in the boots.  I shoved 'em in pretty hard and left the whole thing to sit in the sun for a while.  One beer, two beers, and a little more pressure.  After a couple of hours the boots were stretched enough and they slid right onto the carb intakes.
Someone around my place suggested putting the carb boots into solvent to make them swell, but that didn't sound too good to me, so I never tried it.
Good luck!
1976 CB 750K - Stock / No mods (yet).
