Before you read this post, know this is the first time I've really dove into an engine this heavily. I'm a total novice learning as I go. So if give any wrong info please let me know and I'll modify my post. Thanks.
I DID IT!!!
Hey guys. So I've been a little stuck for a bit, getting the primary shaft out of my 78 550 in order to split the case.
Spitfire, I'm not sure how you were able to split the case without pulling the primary shaft.
And that's the trick! Pulling!!!
Thank you
FunJimmy. I took your advice and tried the engine mount bolt. Worked beautifully!!! What I learned in discussing this with a few different folks on SOHC as well as friends here in Portland is this......at least I think it's this.... on some of the old Honda engines you can pull the oil pump and have good access to the primary shaft and knock it out the other end with a drift. Not on all though! When I took my oil pump off I found that I could only see a fraction of the barrings from the shaft (see pic). Not really enough access to get at it. And from the other side you can see that the shaft has threads on the inside (see other pic).
I just unscrewed the bolt to the right of the shaft that helps keep the barring set in place, screwed the engine mount bolt into the threaded end of the shaft and pulled.....voilà! It popped right out. Freeing up the drive chain and thus allowing me to split the lower casing.
I started this whole process because of serious shifting problems. Once I split the case, had access to the transmission I could see that one of my shifting forks was corroded and tearing up one of my gears. I'm purchasing parts pretty soon.
