Author Topic: Burning oil on cold start  (Read 1149 times)
Offline OakBehringer
« on: November 08, 2008, 01:02:22 PM »
Winter is here and, since I can't ride, it's time to do some more serious engine-off-bike work. On a cold start, I get anywhere from a little to a lot of blue smoke coming out of the pipes. Once it warms up, no more blue smoke. I'm thinking this is probably rings not sealing until it warms up and they expand?
Thanks for the advice,
Adam
1974 350 Four - SOLD
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline Johnie
Re: Burning oil on cold start
« Reply #1 on: November 08, 2008, 01:11:03 PM »
Could be the valve seals leaking down while the bike sits.  Then when you start it up you are burning the oil that seeped past the seals and into the cylinder.  Once you get that burned off it is OK until it sits for a while again.  Have you tried a compression check on it?  Maybe let us know a little more about the bike like miles, etc.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #2 on: November 08, 2008, 01:16:56 PM »
Bike has under 5,000 miles on it, but that doesn't really mean much when it's 34  years old. Who knows how it was maintained for that time.
I did a compression test at the beginning of the summer when I bought it and it was good, but I don't remember the numbers. I don't even remember if I did it hot or cold. What steps should I take to figure this out?
Thanks,
Adam
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline Johnie
« Reply #3 on: November 08, 2008, 07:23:41 PM »
I would say that a 74 with 5,000 miles has been sitting a lot.  All those years of sitting will dry those valve seals out pretty good.  If you only have the blue smoke on start up and not while running, and you have that good compression I would still point to those valve seals.  But...I had this same situation on a 1981 CM400 Custom I bought with 1,300 miles on it.  I took the head off and sure the valve seals were bad, but I put rings in and honed the cylinders as long as I was that far into it.  Good winter project and best of luck with it.
Oshkosh, WI  USA
