Author Topic: Fiberglass Tanks?  (Read 2770 times)
Boziboard
Fiberglass Tanks?
« on: September 23, 2005, 06:37:56 PM »
I was wondering what people think of fiberglass gas tanks and what their experiences have been?  I am converting a 1974 cb750 into a cafe bike and the tank is pretty banged up and those Dunstall replicas look pretty sexy, but I have heard stories of newer formulation gasoline eating away at the tanks resin or getting into the gas itself and resetting in the carbs.  Any feedback would be appreciated.
Offline pwright
    • My SOHC Gallery Page >>
Re: Fiberglass Tanks?
« Reply #1 on: September 23, 2005, 09:00:57 PM »
From my epoxy experience (however none of the stuff I've done has been on tanks...) there are a number of resins that will stand up to fuel. Vinyl Ester resins in particular will work well, but are pretty nasty to work with. People who build composite airplanes commonly have tanks made out of fiberglass and epoxy resins, and I'd be hard pressed to believe the aviation industry would accept anything substandard. Some of these planes have been flying since the late 70s when composites started to change the homebuilt airplane industry- and since the tanks are built into the wings, they haven't been modified since being built. You might want to ask the people who build the cafe tanks what they use, and then do some research on your own as to compatibility.
A good epoxy and fiberglass site I've spent a lot of time on is:
 http://www.fibreglast.com
There should be some good info there...
Best of luck,
-Pat-
Offline oldbiker
  • I HATE RAIN
« Reply #2 on: September 24, 2005, 01:36:10 AM »
Have a look in the Tech Library at  http://sohc4.us/?q=node/53  There is a good article on custom built gas tanks.
« Reply #3 on: September 24, 2005, 02:07:00 AM »
The later Dunstall body kits were just a thin glass cover that went over the standard tank as the UK outlawed fiberglass tanks on bikes built after a certain year (cant remember what year) due to tanks splitting in an accident. Its not a very well know or rigorously enforced rule but Dunstall was a major supplier and so changed his parts.
Offline kyre
    • CB400F / 466 Build Thread
« Reply #4 on: September 24, 2005, 10:04:57 AM »
just remember that fiberglass tanks don't dent when dropped, they crack which "could be" a problem.
CB400F / 466 Build Thread (currently in progress)
http://forums.sohc4.net/index.php?topic=105027.0
Offline Geeto67
  • A grumpy
« Reply #5 on: September 24, 2005, 05:28:17 PM »
if you are worried about your tank you could have a radiator shop put a redliner in it. Redliner is a plastic like coating that is poured in and when it hardens it makes a nearly indestructable liner (the only way to get it out is to burn it out). We used to use it on really rusty steel tanks, may work for fiberglass, and may even give you some piece of mind in a laydown.
Maintenance Matters Most
theunrulychef
« Reply #6 on: September 25, 2005, 06:04:23 AM »
Doh!!!!  Why couldn't I have seen that article BEFORE I started the mold for my tank.  Now I've got the mold plug (positive model of the tank) skimmed with so much bondo trying to get it smooth that I wouldn't want to keep all that weight in there under the fiberglass.  I guess I can either continue down my "positive plug - 2 part negative mold - 2 piece tank glassed together" route, which should give me a smoother, perfectly shaped tank right out of the mold.  Or I can spend 2 hours reshaping some foam, glass the whole thing, & spend another day or two finishing the outside of the tank.  Man, what a sucker!
Thanks SOHC forums... for showing me what a clueless jackass I can be! :'(
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #7 on: February 02, 2007, 09:31:41 PM »
I would be interested in hearing others ideas on this subject.
Would a tank "1975 tracy" that has already worked for 30 years now have issue with new fuel? One would think it's had some new fuel in it already?
Will I need to treat the inside?
Offline puppytrax
« Reply #8 on: February 03, 2007, 03:41:25 AM »
...??...What article??..   ???
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline wardmoto
« Reply #9 on: February 03, 2007, 07:24:31 AM »
pwright is...correct.  While there is a fiberglass/resin combo that works, next to no one does it because it is toxic as hell.  One person in the states does and I have a CR 750 glass tank from him and a CR450 seat pan.  The quality was awesome and just to be on the safe side, I sealed it with tank liner from Bill Hirsch Automotive (there is no better liner!) If there is a legitimate interest let me know, I am not sure how busy he wants to be.  Also, I have it painted and mounted on my recently all but completed 350F cafe, but despite everyone being nice and telling me how to resize pictures, I haven't done it yet!  I can e-mail any pics you want.
03 Suzuki SV 1000S
86 Suzuki GS 550ES
72 Honda CB 350K
72 Honda CB 350F
72 Honda Cb 350F cafe
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #10 on: February 03, 2007, 09:36:51 AM »
OK, here is a whacked idea, glad I stole this ID to ask it!  ;D
What about a fiberglass shell to slip on and off over a existing tank in good shape?  Just for colour and slight contour changes like ribs or a spoiler or a frigg'n cup holder, I don't know!  But, could it be done?
Too whacked?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline paxtonpony
  • Up the Irons!
    • My Pics
« Reply #11 on: February 03, 2007, 01:22:27 PM »
Here's a full dunstall kit if you're looking for one:
http://cgi.ebay.com/ebaymotors/Vintage-Dunstall-Cafe-Motorcycle-Fairing-H2-AHRMA_W0QQitemZ280076869339QQihZ018QQcategoryZ35583QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
BTW, I'm not the seller, just happened upon the thing and thought it was cool.
1969 CB750K - Wrecked
1978 CB750K - Sold
1992 GS500 Streetfighter - Sold
1975 CB750F - Sold (sniff, sniff)
1994 VFR750F - Sold
1990 GSXR 750 - Sold
1999 CBR1100XX - Sold
2000 Triumph Legend TT - Bike of the week for me?
1992 Mustang - Paxton powered (12.02@115mph on street tires) and For Sal
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #12 on: February 03, 2007, 01:28:01 PM »
The one above is one I am selling and it is a cover skin.
The NEW Tracy bike I am getting has a glass tank included with the body.
