Author Topic: Different frame and engine block numbers  (Read 1003 times)
Offline papp101
« on: November 13, 2008, 12:07:38 PM »
Frame:
CB500-1002395
Engine:
CB500E-1002548
Is this standard? I'm pretty sure this was in a flood in 1975 and I'm just trying to research some of the history.
Re: Different frame and engine block numbers
« Reply #1 on: November 13, 2008, 12:11:12 PM »
Frame:
CB500-1002395
Engine:
CB500E-1002548
On Hondas, flood or no flood, engine numbers never match frame numbers. They should each be within certain ranges to confirm you have a K2 engine in a K2 frame for example. Yours are so close I can't imagine a problem.
And even if you had a K3 engine in a K2 frame, or such,  no one counts off for that.  To confirm flood damage, I think you would need to rely on visual inspection of the bike, looking closely for corrosion at wiring plug connections, rust in the headlight bucket (metal?) and the like.
« Last Edit: November 13, 2008, 12:13:59 PM by MCRider »
Offline papp101
« Reply #2 on: November 13, 2008, 12:22:30 PM »
Cool, thanks for the info. I'm mainly going my all the soot that was in the exhaust ports while the mufflers hadn't been taken off and it's been stored inside for the majority of it's non-running life.
Much appreciated!
« Reply #3 on: November 13, 2008, 12:43:36 PM »
Much appreciated!
You're welcome.
Granted those are some nasty pictures. But in the exhaust port I would suspect normal or too rich running. Then sitting for years even inside it will go through condensation cycles that will add lots of water. The rings can be rusted to the cylinders, the exhaust pipes can have rusty holes in them etc. Any area that is mostly sealed up that has air in it can get condensation damage, even when stored inside. Air has water in it, temp change will ring that water out.
Look at the electrical connectors. If they are not stuck together I wouldn't suspect flood damage. Also inside edges of frame tubes, if any are exposed.
Online bryanj
« Reply #4 on: November 13, 2008, 10:51:18 PM »
If you look on the Vin plate I'll bt is says 4/71
