Author Topic: I, um, bought another bike = PIX ADDED  (Read 4279 times)
Re: I, um, bought another bike = PIX ADDED
« Reply #25 on: November 16, 2008, 09:01:33 AM »
I say, Jardine 4-1 with Kerker (or Winning) tailpiece :o
Get on the ground, look under it for evidence of decal or tag.. because the  joint is further out from center of the bike, the tailpiece must be rotated about 1/4 turn, to fit..
Check top tree for cracks, as crunching the instruments put a bit of strain on it (think you said it cracked the paint)..
« Reply #26 on: November 16, 2008, 09:39:06 AM »
It's actually typical of the paint to peel on the K3 and earlier bikes' steering head. Honda just sprayed them, no primer, on metal, like the front caliper. Most all of them peel. After the K4, the finish and prep was better, as was the type of paint used elsewhere. The earlier ones were just enamel.
Offline mrbreeze
  • Not your average
« Reply #27 on: November 16, 2008, 10:26:35 AM »
mrbreeze,
I thought it might be a Kirker but it doesn't have the Kirker cone in the muffler... Maybe it's just missing.
My 550K has a Kirker and it looks like this.
Tatoo,
Too bad about the swim.... A donor motor will pop up...
bc
The primary tubes are to long to be a Kerker
Ahhhhh.....didn't pay much attention to that but the can sure looks like my Kerker.
MEMBER # 257
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #28 on: November 16, 2008, 11:01:46 AM »
Nice looking bike, can't wait to see what you do with it. Should be a pretty simple project if you keep it the way it is  :).
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline Otto
« Reply #29 on: November 16, 2008, 12:57:13 PM »
I'll look under the muffler and see if it has any name on it?
What about the mirrors? Anyone notice, they are really odd or just on the wrong side??
First I will pull he carbs, they're sticky. Clean em, ID them and rebuild them. then adjust valves, tune up and another HONAMAN ignition. Find another set of gauges and a front fender. Then a new set of Avons and wheel bearings and tapered steering bearings, and a swingarm rebuild. Somewhere along the line the motor will get polished..
I also have my 550K project, just bought a 650 cam  and sprocket,a set of 650 gauges, becasue the 550 tach wont work with a 650 cam,Hondaman is going to do the head over the winter, it'll geet a new set of Avons, 38 tooth rear sproket,new chain, wheel bearings, tapered steering bearings, etc. ( it already has a HONDAMAN ignition).
I am restoring a 1980 CB125S basketcase,for a guy in Long Island, NY.
Trying to decide which one to do first...
Bob
« Last Edit: November 16, 2008, 01:25:59 PM by Otto »
Otto
1971 HONDA CB750K1- Valley Green Metallic
2007 Triumph Bonneville - Silver/Black Carburetted
Offline Johnie
« Reply #30 on: November 16, 2008, 05:35:32 PM »
Cool find Otto you lucky guy!!!  While doing all that stuff don't forget to pay some good attention to those forks while they are off.  You will be glad you did.  While I had mine off I was able to remove the clearcoat and they polished up real nice.  Can't wait to see your pics as you progress.  Best of luck on the restore!!!
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Otto
« Reply #31 on: November 16, 2008, 05:58:12 PM »
Thanks John,
I plan on it. Have done a few forks. Usually, 220,320,400,600,800,1000,1500 and polish..
Yours look great, waht's the process you use?
Bob
Otto
helgiman
« Reply #32 on: November 17, 2008, 05:56:17 AM »
I know how you feel. Picked up this one earlier this year In Mass, not too far from you. Serial number in the 17,000 range.
Ed
 ;D
Offline Otto
« Reply #33 on: November 17, 2008, 06:41:20 AM »
Wow! My bikes brother !! (750's are all men, right)! We'll have to have a reunion for them. That is a nice looking bike :D ;)!
Are your gauge faces dark green or black? Mine look dark green and they are damaged...  I may have found a replacement set but they are black ? Wonder if they made black face and green face gauges in 71?
Bob
Otto
Offline UnCrash
  • Pass
    • My Blog
« Reply #34 on: November 17, 2008, 07:04:15 AM »
Nice one Bob!
I'm looking forward to progress pictures.  You sure do make em shine!
helgiman
« Reply #35 on: November 17, 2008, 07:58:31 AM »
They are dark green. A dead give away are the indicator lights built into the gauge faces. Usually the 71 faces were all cracked and faded from the sun. It might be tough finding replacements, but I have seen them every now and then. I have an extra set but_______ they are rusted beyond repair. I mean bad.
Ed
Offline Chris Liston
    • http://christopherliston.com
« Reply #36 on: November 17, 2008, 08:22:13 AM »
How much did you pay for it?  Great find. Good luck.   I wish I could find a barn burner like that.
2008 Triumph Speed Triple Black and NASTY
1976 CB550F Cafe in progress
http://gallery.sohc4.net/main.php?g2_itemId=2402
Offline jkot55
  • Wingman55
« Reply #37 on: November 17, 2008, 09:15:11 AM »
Bob,  great find.  Don't know how you do it.  Good luck with the new project.
When I ride my CB750 I'm a teenager again
Offline Otto
« Reply #38 on: November 17, 2008, 09:18:50 AM »
Hey Wingman!
Thanks..
Good to see you here!
Bob
Otto
Offline Otto
« Reply #39 on: November 18, 2008, 05:41:51 AM »
I have looked all over the exhaust, no manufacturer name or stickers.
I have looked at the stuff Hondaman mentioned yet, been too busy and it's cold outside. :(
bc
Otto
