Author Topic: Any Safari Fans Out There?  (Read 797 times)
Offline Bob Wessner
  • "Carbs Suck!"
« on: November 16, 2008, 10:40:43 AM »
Due to a recent technical limitation of IE that seems to have targeted me alone ::) I've begun using Safari. I wish I had done it sooner, much faster than IE, but then most apps not developed my MS are.
Anyway, one thing I miss is the ability to install Adobe apps in the Google toolbar I had under IE to capture web pages/sites on my local drive as a PDF. Is there any such provision under Safari?
Offline rugger81
Re: Any Safari Fans Out There?
« Reply #1 on: November 16, 2008, 04:45:58 PM »
Google toolbar was probably one of the reasons why you found ie so slow.  Ditch it, and install the open source app pdfcreator.
http://sourceforge.net/project/showfiles.php?group_id=57796&package_id=53473&release_id=627171
Once installed it lets you convert anything you can print to a pdf file.  Just select it as the printer.
'77 CB750K - Rebuild Project Page
'15 Moto Guzzi Griso
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: November 16, 2008, 06:05:27 PM »
Thanks Rugger, I'll give it a try.
Offline Really?
« Reply #3 on: November 16, 2008, 07:41:35 PM »
Could you not just go to File> Print> select Adobe PDF and then choose the Print/Ok button.  This should work if you have Adobe Writer of some form or fashion installed.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: November 17, 2008, 04:09:08 AM »
Yes, tried that. It and PDFCreator work the same way, the only difference is, when I select either as the printer, only the current page displayed is printed, whereas when I used the Adobe app. from the Google Toolbar, once the first file was saved and displayed, I could follow links within the file created and save as much as I wanted and it would all be appended to the same file. Hope that makes sense. No big deal. If I find a multi-page file I want to save, I will just use IE and Google Toolbar for now.
