Author Topic: welding location question for rear set addition  (Read 939 times)
Offline timdhawk
  • 1978 CB750K
« on: November 17, 2008, 03:20:13 PM »
if i were to weld some 7/8" rod/tubing to the lower rear engine mount brace as seen below, would it be better to weld to the outside face of the brace or to drill through it and weld the tube/rod into the brace on the front and back?
thanks
In deeper than I should be...
Offline Triffecpa
Re: welding location question for rear set addition
« Reply #1 on: November 17, 2008, 03:25:25 PM »
probably best to drill all the way thru the bracket and weld the tubing to the inner and outer faces of the bracket.  That way when you insert the bolts to hold the rearsets, you won't try and tighten the bolts and squish the bracket.
TR
