Hi Guys,I have a 1974 CB750........ K4....... mileage just now going over 30,000........... this will be the first time I have done this
![Tongue :P](http://forums.sohc4.net/Smileys/default/tongue.gif)
Going to pull the crankcase plate on the bottom of the engine when I do the next oil change........... cleanup everything down there........ the oil pump screen, blah, blah, blah.
I have a new cork gasket from Honda. Should I use a sealant on the parts? Apply to engine or plate; or gasket? If so, what brand/type would you recommend?
Thanks in advance for input.
![Cheesy :D](http://forums.sohc4.net/Smileys/default/cheesy.gif)
~ ~ ~ jaknight ~ ~ ~
