Author Topic: carb kits for 74 cb550 k  (Read 1416 times)
jsaab2748
« on: September 25, 2005, 08:49:39 PM »
Looking for suggestions as to which brand of carb kits give the best results, (when properly installed of course), and part numbers for such kits if available. Bike is a totally stock cb 550 k0 with original carbs. Also, where is the best place to get them? Thanks...jim
Re: carb kits for 74 cb550 k
« Reply #1 on: September 26, 2005, 12:23:44 AM »
I've not found a need to replace any parts inside these carbs besides the o rings and seals.  These are all contained in kits available from Honda.  $15-$20 per carb.
 If you don't have a local Honda Dealer or motorcycle shop that will help you, You could try these.
http://www.sohc4.us/forums/index.php?topic=743.0
Offline 74cb750
« Reply #2 on: September 28, 2005, 07:11:44 AM »
Laugh at least once a day.
Life  $ucks, then you die.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #3 on: September 28, 2005, 08:58:23 AM »
Yes it does.  But it doesn't go to carb kits (it goes to the German tank/sidecover emblem site)
There is a link in the FAQs for carb kits.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
