Author Topic: ANY OTHER RD OWNERS HERE?  (Read 1588 times)
Offline siter81
  • vintage bike junkie!
  • TOO MANY BIKES? NEVER
« on: November 25, 2008, 12:27:43 PM »
I have a 75 350 i am having a funky issue with?It runs fine until i go to stop and then doesnt want to idle.Have checked timing.swapped carbs etc?
Anyone have any ideas?
61 BMW R27 70 BMW R75/5  75 RD350
71 SUZUKI T500
75 CB750K5  Weisco 836, WEB CAM.DYNA IGN,KERKER,K&N,TAYLOR,GALFER,AGM ETC.
 01 HONDA VC11000C3 AERO.
74&75 DUCATI 860 GT'S
Offline heffay
Re: ANY OTHER RD OWNERS HERE?
« Reply #1 on: November 25, 2008, 01:52:25 PM »
air leak somewhere in the rubber manifolds would be my guess...
i wish i had a pic of the old rd400, was kindof a rat bike, we called it the pickle... bet you can't guess why.   ;D
btw, rat bike doesn't mean it wasn't a screamer!!!
Offline cb650
« Reply #2 on: November 25, 2008, 04:05:43 PM »
I found a place that has a few old rd's laying around.  From a 250 to a 79 DS.  Dont know how to deal with them and the bike as I am still trying to get a 650 from them.
Offline Maxacceleration
« Reply #3 on: November 25, 2008, 04:52:52 PM »
You could have any one of several problems. Just a rich RD wont idle sometimes.
Go to USA 2strokers. They'll help get you sorted.http://www.usa2strokers.com/forum/default.asp
 ;D
Olden is Golden
CR550F RD400 KZ550 KH500
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #4 on: November 26, 2008, 06:46:09 AM »
If you've done carb work there is a major pitfall many RD owners run into. This happened to me with pretty much the same issue your having. It involves your float bowls. Look at the float bowls. They look pretty much alike, but with very close inpection you will find they are not alike. One has a hole that the other doesn't have. If the bowls are reversed you will have problems. Now it's been a long time since I dealt with this, so I'm going from very old memory. So I may not even remember the details exactly.
On the bottom of you carbs, you have a long tube. When you put on the float bowls this long tube goes into the round hole in the float bowl. Look at each float bowl very very close. At the base of the float bowl where the tube goes. Look at the bottom. You will find one float bowl has a hole and one doesn't. Get these bowls reversed and in the wrong place and you got grief.
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
Offline siter81
« Reply #5 on: November 27, 2008, 05:18:48 PM »
Thanks for  the heads up.I am a member of the U.S.A strokers forum.But just wanted another view or thought on my problem.I have checked the carb manifolds,they seem ok,i have another set i think i will swap with.I will also check the float deal mentions,Not sure on that thou cause even with the other carbs it did the same thing? All is stock except uni open end filters.
Thanks to all replies   Siter81  Aka Ed.S
71 SUZUKI T500
Offline A Grove
  • Some people call me a
« Reply #6 on: December 04, 2008, 10:29:19 PM »
how rare are these bikes?  What about parts availability, etc?  I am loving the idea of having a two-stroke for whizzing around town.  are they rare or fairly common?
I HATE to threadjack here...
