Author Topic: Fuel petcock valve question  (Read 1516 times)
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« on: November 26, 2008, 01:04:12 PM »
Im assuming that my 750f petcock has an o-ring of some sort that goes between it and the tank? Right? And where can I get a new one? Or is there something that I can use inplace of it? Pipe tape or gasket sealer?
       Jim
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline Triffecpa
Re: Fuel petcock valve question
« Reply #1 on: November 26, 2008, 01:08:11 PM »
Most of them thread onto a male pipe thread bung that is welded to the tank.  If it's leaking around the threads, unscrew the petcock and wrap some teflon tape around the bung and reattach the petcock.  Others have claimed that teflon tape won't hold up to gas, but I've not had any problems using it.
Tracy
Offline JS550
  • IAFF local 1307
« Reply #2 on: November 26, 2008, 01:11:38 PM »
Ok, that's what I needed. I picked up the tank without a petcock on it, it does have the welded bung though, & seem to remember my 550 having a little rubber o-ring but I just used some gasket stuff that I'm guessing has made the petcock a permanent part of the tank! But thought I would check this time around.
        thanks
Offline davesprinkle
« Reply #3 on: November 26, 2008, 04:42:10 PM »
       Jim
Pipe-threads have a tapered diameter and are designed to seal on the threads.  The petcock bung is NOT a pipe-thread -- its diameter is consistent along its length.  It is designed to seal on a crush washer.  Do not attempt to use pipe tape to seal a straight thread.  It MIGHT work, but probably not, and then when it leaks, you've got a fire risk.  Just do it correctly and get a replacement washer.
Offline dn4911
  • a work in progress
« Reply #4 on: November 26, 2008, 06:52:39 PM »
I took the petcock off the tank of a 550 supersport tank and it looked like there was a gasket there.  I bought some gasket material and was going to just cut out a new one.  ANy problem with that?
CB550 K1
« Reply #5 on: November 26, 2008, 10:26:28 PM »
Cutting out a gasket MIGHT work, depending on the gasket material and how tightly you clamp it up.  The stocker was a somewhat thick (maybe 2mm?) ring.  Sorry, I don't recall the material.  My Pingel petcock, which seals in a similar manner, includes a 2mm thick plastic sealing ring.
I would suggest ordering up the stock part.  It's probably still available and likely will cost less than $10.
« Reply #6 on: November 26, 2008, 11:34:05 PM »
What year F tank did you get?  The 77's had a different bung size.  In both cases, there is an in tank filter.  Just different styles.  The gasket is also different between them.  For certain, teflon tape is the wrong way to go.  And, if you use the white type it is attacked by hydrocarbons.  The yellow type is used for gas situations.  But, as I said, teflon tape is just the wrong application for the bung threads.  The seal is to be made against at the end of the tank bung, not the threads.
Offline dn4911
« Reply #7 on: November 27, 2008, 09:57:04 AM »
Don't know what year the F tank is.  It came as a throw in with the 75 K1 550.  Yes the filter is inline, actually it looks from the outside just like the K filter.  For some reason I thought it was off a 76.
CB550 K1
« Reply #8 on: November 27, 2008, 10:16:53 AM »
What is the width of the tank bung?
Offline jtb
  • An unlikely
« Reply #9 on: November 27, 2008, 08:05:13 PM »
The 77&78's had a fibre washer that went inside the nut on the petcock.  They're only good for one shot.  I replaced mine with an o-ring a couple of years ago with no problems.  I got an assortment of o-rings at an auto parts store.
1977 CB750F
1985 V65 Sabre
Offline ngonerogwu
  • cb350/550
« Reply #10 on: June 08, 2013, 01:13:40 PM »
I just used a 10.8 id, 15.6 od, 2.4 section on my 77k petcock.
Offline uksparky
  • Track days
« Reply #11 on: June 08, 2013, 08:58:21 PM »
My tank bung is 3/4 inch 1.5 mm threads....is that 16mm....or 18mm having a hard time finding petcock 90 degree
Present bike 1982 900C Custom
