Author Topic: backfiring!?!  (Read 1126 times)
jmill0823
backfiring!?!
« on: September 26, 2005, 11:25:35 AM »
My 81 CB650 is backfiring every time I let off the gas or when I'm pulling the clutch in as I slow down.  I also have to keep the choke all the way out or it will die.  What should I do to get it running right?   ???
Offline hymodyne
Re: backfiring!?!
« Reply #1 on: September 26, 2005, 11:50:05 AM »
go to carb FAQ, for starters...
hym
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: backfiring!?!
« Reply #2 on: September 26, 2005, 11:52:18 AM »
Sounds like an air leak.  Keeping the coke "out" (assume you mean closed) will richen up the mixture enough to keep it going.
Check the FAQs or search on "air leak"
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
