Author Topic: # 3 pipe not as hot as others ? 72 CB500  (Read 1480 times)
Offline 78 k550
« on: September 26, 2005, 09:02:37 PM »
Hey All,
 My # 3 pipe doesnt get nearly as hot as my other's. I don't think this is normal. I'll be pulling the plug's tomorrow and change them out with new one's. That would be the easiest. Would low compression cause this also? Seem's to run real smooth. I can ride it alot longer now I have the charging sytem fixed. Was only getting 7.6 volt's at the battery. Cleaned up the point's with a file, wiped them and sytem is charging at 12.5 volt's. :)  I was hopeing it was the no charging that was keeping the # 3 pipe from getting as hot as the others. It is the same.
 Are platinum plugs good to run in these old bike's?
Thank's
 Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
LeoLegendATL
Re: # 3 pipe not as hot as others ? 72 CB500
« Reply #1 on: September 26, 2005, 10:02:45 PM »
Sounds like you got a carb and an air fuel mixture problem.  Check and make sure your idle screws and carbs are working properly, ie floats and jets not clogged.
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #2 on: September 26, 2005, 10:52:37 PM »
When you pull the plugs make sure you're getting good spark on #3.  If it's fine, then it's the cylinder running too lean.  If there's no spark/weak spark, check the plug caps and coils for damage or grounding.
CB750K4
« Reply #3 on: September 27, 2005, 09:17:18 AM »
In addition to spark and compression issues would be carburation; cleanliness, settings, and syncronization.
Time to start an isolative process that confirms or exposes each item needed for even combustion across the cylinders.
Wouldn't hurt to do a complete tuneup procedure as a starting basis.
